Hi Everyone!
I was excited to get this gateway. I hooked it up and followed the instructions to connect it to TTN. The gateway phases the red led. It doesn’t seem to get any lora packets. I tested with another brand gateway, and it is able to receive lora packets fine. Is it possible that I have a bad gateway? Or is something not configured properly?
System Log:
Tue Nov 16 16:43:56 2021 daemon.notice netifd: Interface 'wan' has link connectivity loss
Tue Nov 16 16:43:56 2021 daemon.notice netifd: Interface 'alias' has link connectivity loss
Tue Nov 16 16:43:56 2021 daemon.notice netifd: Interface 'wan6' has link connectivity loss
Tue Nov 16 16:43:56 2021 daemon.notice netifd: Network device 'eth0' link is down
Tue Nov 16 16:43:57 2021 user.err basicstation[2660]: [TCE:ERRO] TC connect failed - URI: wss://nam1.cloud.thethings.network:8887
Tue Nov 16 16:43:57 2021 user.notice esw: esw link state changed : down - ifup wan
Tue Nov 16 16:43:58 2021 user.notice simple_multi_wan: starting mwan3
Tue Nov 16 16:43:58 2021 user.emerg syslog: Cannot find device "eth0.2"
Tue Nov 16 16:43:58 2021 user.notice root: drv_ralink_cleanup
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'lan' is enabled
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'lan' is setting up now
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'lan' is now up
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'wan' is enabled
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'alias' is enabled
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'alias' is setting up now
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'alias' is now up
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'wan6' is enabled
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'loopback' is enabled
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'loopback' is setting up now
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'loopback' is now up
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'wan0' is enabled
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'wan06' is enabled
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Bridge 'br-lan' link is up
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'lan' has link connectivity
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Network device 'eth0' link is up
Tue Nov 16 16:43:59 2021 daemon.notice netifd: VLAN 'eth0.1' link is up
Tue Nov 16 16:43:59 2021 daemon.notice netifd: VLAN 'eth0.2' link is up
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'wan' has link connectivity
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'wan' is setting up now
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'alias' has link connectivity
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'wan6' has link connectivity
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'wan6' is setting up now
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Network device 'lo' link is up
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'loopback' has link connectivity
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Network device 'apcli0' link is up
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'wan0' has link connectivity
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'wan0' is setting up now
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'wan06' has link connectivity
Tue Nov 16 16:43:59 2021 daemon.notice netifd: Interface 'wan06' is setting up now
Tue Nov 16 16:43:59 2021 daemon.notice netifd: wan0 (3300): udhcpc: option -h NAME is deprecated, use -x hostname:NAME
Tue Nov 16 16:43:59 2021 daemon.notice netifd: wan0 (3300): udhcpc (v1.23.2) started
Tue Nov 16 16:43:59 2021 daemon.notice netifd: wan (3308): udhcpc: option -h NAME is deprecated, use -x hostname:NAME
Tue Nov 16 16:43:59 2021 daemon.notice netifd: wan (3308): udhcpc (v1.23.2) started
Tue Nov 16 16:44:00 2021 daemon.notice netifd: radio0 (3229): Interface doesn't accept private ioctl...
Tue Nov 16 16:44:00 2021 daemon.notice netifd: radio0 (3229): set (8BE2): Invalid argument
Tue Nov 16 16:44:00 2021 daemon.notice netifd: wan0 (3300): Sending discover...
Tue Nov 16 16:44:00 2021 user.notice ping-watchdog: lan br-lan ifup
Tue Nov 16 16:44:00 2021 daemon.notice netifd: wan (3308): Sending discover...
Tue Nov 16 16:44:00 2021 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Tue Nov 16 16:44:01 2021 daemon.notice netifd: Network device 'ra0' link is up
Tue Nov 16 16:44:01 2021 daemon.info dnsmasq[3343]: started, version 2.73 cachesize 150
Tue Nov 16 16:44:01 2021 daemon.info dnsmasq[3343]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC loop-detect inotify
Tue Nov 16 16:44:01 2021 daemon.info dnsmasq[3343]: DNS service limited to local subnets
Tue Nov 16 16:44:01 2021 daemon.info dnsmasq-dhcp[3343]: DHCP, IP range 192.168.230.100 -- 192.168.230.249, lease time 12h
Tue Nov 16 16:44:01 2021 daemon.info dnsmasq[3343]: using local addresses only for domain lan
Tue Nov 16 16:44:01 2021 daemon.warn dnsmasq[3343]: no servers found in /tmp/resolv.conf.auto, will retry
Tue Nov 16 16:44:01 2021 daemon.info dnsmasq[3343]: read /etc/hosts - 1 addresses
Tue Nov 16 16:44:01 2021 daemon.info dnsmasq[3343]: read /tmp/hosts/dhcp - 1 addresses
Tue Nov 16 16:44:01 2021 daemon.info dnsmasq[3343]: read /tmp/hosts/odhcpd - 0 addresses
Tue Nov 16 16:44:01 2021 daemon.info dnsmasq-dhcp[3343]: read /etc/ethers - 0 addresses
Tue Nov 16 16:44:01 2021 user.notice esw: esw link state changed : up - ifup wan
Tue Nov 16 16:44:02 2021 daemon.notice netifd: wan (3308): Received SIGTERM
Tue Nov 16 16:44:02 2021 daemon.notice netifd: Interface 'wan' is now down
Tue Nov 16 16:44:02 2021 daemon.notice netifd: Interface 'wan' is setting up now
Tue Nov 16 16:44:02 2021 daemon.notice netifd: wan (3486): udhcpc: option -h NAME is deprecated, use -x hostname:NAME
Tue Nov 16 16:44:02 2021 daemon.notice netifd: wan (3486): udhcpc (v1.23.2) started
Tue Nov 16 16:44:02 2021 daemon.notice netifd: wan (3486): Sending discover...
Tue Nov 16 16:44:02 2021 daemon.notice netifd: wan (3486): Sending select for 192.168.0.153...
Tue Nov 16 16:44:02 2021 daemon.notice netifd: wan (3486): Lease of 192.168.0.153 obtained, lease time 7200
Tue Nov 16 16:44:02 2021 daemon.notice netifd: Interface 'wan' is now up
Tue Nov 16 16:44:02 2021 daemon.info dnsmasq[3343]: reading /tmp/resolv.conf.auto
Tue Nov 16 16:44:02 2021 daemon.info dnsmasq[3343]: using local addresses only for domain lan
Tue Nov 16 16:44:02 2021 daemon.info dnsmasq[3343]: using nameserver 192.168.0.1#53
Tue Nov 16 16:44:02 2021 daemon.notice netifd: wan (3486): Warning: Executing wildcard deletion to stay compatible with old scripts.
Tue Nov 16 16:44:02 2021 daemon.notice netifd: wan (3486): Explicitly specify the prefix length (169.254.122.175/32) to avoid this warning.
Tue Nov 16 16:44:02 2021 daemon.notice netifd: wan (3486): This special behaviour is likely to disappear in further releases,
Tue Nov 16 16:44:02 2021 daemon.notice netifd: wan (3486): fix your scripts!
Tue Nov 16 16:44:03 2021 daemon.notice netifd: wan0 (3300): Sending discover...
Tue Nov 16 16:44:03 2021 daemon.info dnsmasq[3343]: exiting on receipt of SIGTERM
Tue Nov 16 16:44:03 2021 daemon.info dnsmasq[3538]: started, version 2.73 cachesize 150
Tue Nov 16 16:44:03 2021 daemon.info dnsmasq[3538]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC loop-detect inotify
Tue Nov 16 16:44:03 2021 daemon.info dnsmasq[3538]: DNS service limited to local subnets
Tue Nov 16 16:44:03 2021 daemon.info dnsmasq-dhcp[3538]: DHCP, IP range 192.168.230.100 -- 192.168.230.249, lease time 12h
Tue Nov 16 16:44:03 2021 daemon.info dnsmasq[3538]: using local addresses only for domain lan
Tue Nov 16 16:44:03 2021 daemon.info dnsmasq[3538]: reading /tmp/resolv.conf.auto
Tue Nov 16 16:44:03 2021 daemon.info dnsmasq[3538]: using nameserver 192.168.0.1#53
Tue Nov 16 16:44:03 2021 daemon.info dnsmasq[3538]: read /etc/hosts - 1 addresses
Tue Nov 16 16:44:03 2021 daemon.info dnsmasq[3538]: read /tmp/hosts/dhcp - 1 addresses
Tue Nov 16 16:44:03 2021 daemon.info dnsmasq[3538]: read /tmp/hosts/odhcpd - 0 addresses
Tue Nov 16 16:44:03 2021 daemon.info dnsmasq-dhcp[3538]: read /etc/ethers - 0 addresses
Tue Nov 16 16:44:04 2021 user.notice ping-watchdog: alias eth0.2 ifup
Tue Nov 16 16:44:04 2021 user.notice firewall: Reloading firewall due to ifup of alias (eth0.2)
Tue Nov 16 16:44:05 2021 user.notice mwan3: ifup interface wan (eth0.2)
Tue Nov 16 16:44:06 2021 daemon.notice netifd: wan0 (3300): Sending discover...
Tue Nov 16 16:44:06 2021 daemon.info dnsmasq[3538]: exiting on receipt of SIGTERM
Tue Nov 16 16:44:06 2021 daemon.info dnsmasq[3794]: started, version 2.73 cachesize 150
Tue Nov 16 16:44:06 2021 daemon.info dnsmasq[3794]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-auth no-DNSSEC loop-detect inotify
Tue Nov 16 16:44:06 2021 daemon.info dnsmasq[3794]: DNS service limited to local subnets
Tue Nov 16 16:44:06 2021 daemon.info dnsmasq-dhcp[3794]: DHCP, IP range 192.168.230.100 -- 192.168.230.249, lease time 12h
Tue Nov 16 16:44:06 2021 daemon.info dnsmasq[3794]: using local addresses only for domain lan
Tue Nov 16 16:44:06 2021 daemon.info dnsmasq[3794]: reading /tmp/resolv.conf.auto
Tue Nov 16 16:44:06 2021 daemon.info dnsmasq[3794]: using nameserver 192.168.0.1#53
Tue Nov 16 16:44:06 2021 daemon.info dnsmasq[3794]: read /etc/hosts - 1 addresses
Tue Nov 16 16:44:06 2021 daemon.info dnsmasq[3794]: read /tmp/hosts/dhcp - 1 addresses
Tue Nov 16 16:44:06 2021 daemon.info dnsmasq[3794]: read /tmp/hosts/odhcpd - 0 addresses
Tue Nov 16 16:44:06 2021 daemon.info dnsmasq-dhcp[3794]: read /etc/ethers - 0 addresses
Tue Nov 16 16:44:07 2021 user.notice ping-watchdog: wan eth0.2 ifup
Tue Nov 16 16:44:07 2021 user.notice firewall: Reloading firewall due to ifup of wan (eth0.2)
Tue Nov 16 16:44:09 2021 user.notice ping-watchdog: loopback lo ifup
Tue Nov 16 16:44:09 2021 user.emerg syslog: uci: Entry not found
Tue Nov 16 16:44:21 2021 user.warn basicstation[2660]: [LOG:WARN] LoRa modulation error: 0
Tue Nov 16 16:44:23 2021 user.warn mwan3: Could not find gateway for interface wan0 (apcli0)
Tue Nov 16 16:44:23 2021 user.notice ping-watchdog: wan0 apcli0 ifup
Tue Nov 16 16:44:23 2021 user.notice firewall: Reloading firewall due to ifup of wan0 (apcli0)
Tue Nov 16 16:44:24 2021 user.emerg syslog: uci: Entry not found
Tue Nov 16 16:44:27 2021 user.emerg syslog: Cannot find device "wwan0"
Tue Nov 16 16:44:27 2021 user.notice mwan3: ifup interface wan (eth0.2)
Tue Nov 16 16:44:28 2021 user.emerg syslog: Cannot find device "wwan0"
Tue Nov 16 16:44:28 2021 user.notice ping-watchdog: wan eth0.2 ifup
Tue Nov 16 16:44:28 2021 user.notice firewall: Reloading firewall due to ifup of wan (eth0.2)
Tue Nov 16 16:44:29 2021 user.emerg syslog: Cannot find device "wwan0"
Tue Nov 16 16:44:30 2021 user.emerg syslog: Cannot find device "wwan0"
Tue Nov 16 16:44:31 2021 user.emerg syslog: Cannot find device "wwan0"
Tue Nov 16 16:44:32 2021 user.emerg syslog: Cannot find device "wwan0"
Tue Nov 16 16:44:33 2021 user.emerg syslog: Cannot find device "wwan0"
Tue Nov 16 16:44:34 2021 user.emerg syslog: Cannot find device "wwan0"
Tue Nov 16 16:44:35 2021 user.emerg syslog: Cannot find device "wwan0"
Tue Nov 16 16:44:36 2021 user.emerg syslog: Cannot find device "wwan0"
Tue Nov 16 16:44:37 2021 user.warn mwan3: Could not find gateway for interface wwan (wwan0)
Tue Nov 16 16:44:37 2021 user.notice ping-watchdog: wwan wwan0 ifup
Tue Nov 16 16:44:37 2021 user.notice firewall: Reloading firewall due to ifup of wwan (wwan0)
Tue Nov 16 16:44:38 2021 user.emerg syslog: uci: Entry not found
Tue Nov 16 16:44:40 2021 user.emerg syslog: sh: on: unknown operand
Tue Nov 16 16:44:40 2021 user.emerg syslog: /etc/rc.common: line 30: breathe_led.sh: not found
Tue Nov 16 16:44:42 2021 user.emerg syslog: setting up led eth0
Tue Nov 16 16:44:47 2021 daemon.info procd: - init complete -
Tue Nov 16 16:44:51 2021 user.notice breathing_light: set breathing light to ABNORMAL
Tue Nov 16 16:44:55 2021 kern.info quectel-CM[2264]: Cannot find qmichannel((null)) usbnet_adapter((null)) for Quectel modules
Tue Nov 16 16:51:08 2021 kern.info quectel-CM[6032]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Tue Nov 16 16:51:08 2021 kern.info quectel-CM[6032]: /usr/sbin/quectel profile[1] = (null)/(null)/(null)/0, pincode = (null)
Tue Nov 16 16:51:08 2021 user.notice root: echo 1 > /sys/class/gpio/gpio0/value
Tue Nov 16 16:51:09 2021 user.notice root: echo 0 > /sys/class/gpio/gpio0/value
Tue Nov 16 16:51:38 2021 user.warn basicstation[8003]: [SYS:WARN] Station in NO-CUPS mode
Tue Nov 16 16:52:23 2021 kern.info quectel-CM[6032]: Cannot find qmichannel((null)) usbnet_adapter((null)) for Quectel modules
Tue Nov 16 16:52:25 2021 kern.info quectel-CM[10800]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Tue Nov 16 16:52:25 2021 kern.info quectel-CM[10800]: /usr/sbin/quectel profile[1] = (null)/(null)/(null)/0, pincode = (null)
Tue Nov 16 16:52:25 2021 user.notice root: echo 1 > /sys/class/gpio/gpio0/value
Tue Nov 16 16:52:26 2021 user.notice root: echo 0 > /sys/class/gpio/gpio0/value
Tue Nov 16 16:53:39 2021 kern.info quectel-CM[10800]: Cannot find qmichannel((null)) usbnet_adapter((null)) for Quectel modules
Tue Nov 16 16:53:41 2021 kern.info quectel-CM[15430]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Tue Nov 16 16:53:41 2021 kern.info quectel-CM[15430]: /usr/sbin/quectel profile[1] = (null)/(null)/(null)/0, pincode = (null)
Tue Nov 16 16:53:41 2021 user.notice root: echo 1 > /sys/class/gpio/gpio0/value
Tue Nov 16 16:53:42 2021 user.notice root: echo 0 > /sys/class/gpio/gpio0/value
Tue Nov 16 16:54:55 2021 kern.info quectel-CM[15430]: Cannot find qmichannel((null)) usbnet_adapter((null)) for Quectel modules
Tue Nov 16 16:54:57 2021 kern.info quectel-CM[20025]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Tue Nov 16 16:54:57 2021 kern.info quectel-CM[20025]: /usr/sbin/quectel profile[1] = (null)/(null)/(null)/0, pincode = (null)
Tue Nov 16 16:54:57 2021 user.notice root: echo 1 > /sys/class/gpio/gpio0/value
Tue Nov 16 16:54:58 2021 user.notice root: echo 0 > /sys/class/gpio/gpio0/value
Tue Nov 16 16:56:12 2021 kern.info quectel-CM[20025]: Cannot find qmichannel((null)) usbnet_adapter((null)) for Quectel modules
Tue Nov 16 16:56:14 2021 kern.info quectel-CM[24684]: WCDMA<E_QConnectManager_Linux&Android_V1.1.38
Tue Nov 16 16:56:14 2021 kern.info quectel-CM[24684]: /usr/sbin/quectel profile[1] = (null)/(null)/(null)/0, pincode = (null)
Tue Nov 16 16:56:14 2021 user.notice root: echo 1 > /sys/class/gpio/gpio0/value
Tue Nov 16 16:56:15 2021 user.notice root: echo 0 > /sys/class/gpio/gpio0/value
Unless something is going wrong that is making it glow red?
