mehmet
(mehmet)
1
well there is an example in Arduino ide LORAWAN OTAA
at this code if I plan to 2 motnhs about 5,000,000,000 OTAA Period it gives error. ın my opinion uint32_t should choice instead of uint64_t
void loop()
static uint64_t last = 0;
static uint64_t elapsed;
if ((elapsed = millis() - last) > OTAA_PERIOD) {
uplink_routine();
last = millis();
//Serial.printf("Try sleep %ums..", OTAA_PERIOD);
api.system.sleep.all(OTAA_PERIOD);
//Serial.println("Wakeup..");
beegee
(Bernd Giesecke)
3
millis() is an unsigned long which is 32bit.
Your calculation where you mix uint64_t with unsigned long (32 bits) will fail already at some point.
api.system.sleep.all() is calling udrv_sleep_ms(uint32_t ms_time) which is 32bit only as well.
If you need to sleep for 2 months, you have to use another method. Maybe an external RTC with a wake-up function.
There are other options to keep the device in low power mode without using loop() and api.system.sleep.all(OTAA_PERIOD);
Maybe RUI3-LowPower-Example can give you an insight. However, there is no timer that would hit only every 2 months.
system
(system)
Closed
4
