Issue in P2P rx
Hi friends,
I have trouble with rak811 in P2P mode. the issue occurs in sometimes. I put one node in P2P RX mode. sometimes the receiver doesn’t receive anything. but after some seconds, it receives a not valid data with not valid size. for example I should receive “hello world” but I receive an 186 bytes array with random bytes. However, sometimes I receive correct payload “hello world”.
how can I find the solution?
not valid payload array
valid payload array
as you see, there isn’t any relation between them
Hi @king,
Which version of RAK811 firmware are you using?
I had deeper tests, in receiver sometimes I receive, sometimes I don’t receive, sometimes I get rx_P2PrxErrror.
edit: actually, P2P connection is not stable, even in low range tests in some endnodes (rak811);
Hi @king,
Are you using the open source version firmware of RAK811 from Github?
yes, I’m using the open source version.
Hi @king,
Maybe you can try our commercial firmware of RAK811.
Please have a look at this document:
https://downloads.rakwireless.com/en/LoRa/RAK811/Application_Notes/
You can find the commercial firmware and how to use P2P mode in this document.
do you mean I use at command method?
actually, I want the code to operate automatically.
Hi @king,
Actually, every AT command has called an API, and we have supplied a set of API for users to customize based on our commercial firmware.
Maybe you can havea look at this topic:
@Fomi, I have tested your modules with AT+Command procedure. but sometimes, I didn’t receive the signal in gateway. in simple words, some modules is unstable in P2P transmission.
a question: is it necessary to reset the micro after mode changing (lorawan and p2p)?
if I want to avoid resetting the micro what should I do?
a question: is it necessary to write to partition after some at commands (those in your code, like rf_config)? if I want to avoid, what should I do?
