I’m using a RAK 7258 gateway and several sensors from RAK and Dragino.
After updating the firmware I’m unable to add new sensors (Dragino LHT65, in this case) to the application. They have a common issue: the OTAA Join fails.
I put the old firmware back, but then the application section couln’t be opened anymore (got an html error saying that certain files couldn’t be accessed.).
To sum it up, I did a fresh install with the latest firmware, started from scratch, made new applications and ran into the same issue as in the beginning, no OTAA Join.
When I look into the logfile I see:
__nsParseJoinReq: join_req mic check failed
The APPeui and APPSkey are correctly set in the Dragino, and the DEVeui is set in the application.
One particular thing which I can notice, but I have no means to compare it with other sensors, is that if I look at the join request, I see:
"JoinRequest": {
"AppEUI": "DC F1 66 7F 6A 4C 7F 77 ",
"DevEUI": "A4 40 21 05 01 31 ED 67 ",
"DevNonce": "BA52"
Note that there’s a space behind the 77 in the AppEUI ánd after 67 in the DevEUI, I can imagine this being an issue, but no idea how to change it. In the Dragino sensor I don’t have any options concerning this.
The AppEUI and DevEUI are correct valuewise.
Application details:
Device auth mode: unified app key (tried both options)
Auto add LoRa device: on
If anyone can point me out in the right direction…would be appreciated!
