I’m trying to pair the RAK4631 with Dragino’s DLOS8, so far I’ve been able to get data to appear to be received by the gateway, but for some reason the gateway rejects it, citing an invalid fcnt every time. I’m using ABP mode with the gateway’s ABP decryption function (local network server).
Data appearing on gateway:
Mon Oct 4 21:49:43 2021 daemon.info lora_pkt_fwd[2661]: RXTX~ {"rxpk":[{"tmst":1027488172,"time":"2021-10-04T21:49:46.434830Z","tmms":4434,"chan":3,"rfch":0,"freq":902.900000,"stat":1,"modu":"LORA","datr":"SF8BW125","codr":"4/5","lsnr":12.5,"rssi":-78,"size":33,"data":"gDU0MzKAAAACaoCirlQyU4FKWw0TeeZ2vnpEM4obVZiq"}]}
Sketch that sends data:
#include <Arduino.h>
#include <SPI.h>
// RAK4630 supply two LED
#ifndef LED_BUILTIN
#define LED_BUILTIN 35
#endif
#ifndef LED_BUILTIN2
#define LED_BUILTIN2 36
#endif
bool doOTAA = false; // OTAA is used by default.
#define LORAWAN_DATERATE DR_3 /*LoRaMac datarates definition, from DR_0 to DR_5*/
#define LORAWAN_TX_POWER TX_POWER_5 /*LoRaMac tx power definition, from TX_POWER_0 to TX_POWER_15*/
#define JOINREQ_NBTRIALS 0 /**< Number of trials for the join request. */
DeviceClass_t g_CurrentClass = CLASS_A; /* class definition*/
LoRaMacRegion_t g_CurrentRegion = LORAMAC_REGION_US915; /* Region:EU868*/
lmh_confirm g_CurrentConfirm = LMH_CONFIRMED_MSG; /* confirm/unconfirm packet definition*/
static lmh_param_t g_lora_param_init = {LORAWAN_ADR_ON, LORAWAN_DATERATE, LORAWAN_PUBLIC_NETWORK, JOINREQ_NBTRIALS, LORAWAN_TX_POWER, LORAWAN_DUTYCYCLE_OFF};
// Foward declaration
static lmh_callback_t g_lora_callbacks = {BoardGetBatteryLevel, BoardGetUniqueId, BoardGetRandomSeed,
lorawan_rx_handler, lorawan_has_joined_handler, lorawan_confirm_class_handler, lorawan_join_failed_handler
//OTAA keys !!!! KEYS ARE MSB !!!!
uint8_t nodeDeviceEUI[8] = {0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x33, 0x33};
uint8_t nodeAppEUI[8] = {0xB8, 0x27, 0xEB, 0xFF, 0xFE, 0x39, 0x00, 0x00};
uint8_t nodeAppKey[16] = {0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88, 0x88};
// ABP keys
uint32_t nodeDevAddr = 0x32333435;
uint8_t nodeNwsKey[16] = {0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x10, 0x12, 0x13, 0x14, 0x14, 0x15, 0x16};
uint8_t nodeAppsKey[16] = {0x17, 0x18, 0x19, 0x20, 0x21, 0x22, 0x23, 0x24, 0x25, 0x26, 0x27, 0x28, 0x29, 0x30, 0x31, 0x32};
// Private defination
#define LORAWAN_APP_DATA_BUFF_SIZE 21 /**< buffer size of the data to be transmitted. */
#define LORAWAN_APP_INTERVAL 30000 /**< Defines for user timer, the application data transmission interval. 20s, value in [ms]. */
TimerEvent_t appTimer;
static uint32_t count = 0;
unsigned int thingNum = 1130;
byte appNum = 69;
byte mac[] = {0x26, 0x01, 0x16, 0xF9, 0xFF, 0xFF};
unsigned long time = 1632942051000;
float flo = 2.31;
int in = -1500;
byte bs = 0b01010101;
byte Lpacket[20];
union Union
float flt;
unsigned char flBytes[4];
void setup() {
// put your setup code here, to run once:
preparePacket();
pinMode(LED_BUILTIN, OUTPUT);
// Initialize LoRa chip.
lora_rak4630_init();
time_t timeout = millis();
while (!Serial)
delay(100);
else
break;
if (doOTAA)
Serial.println("Type: OTAA");
else
Serial.println("Type: ABP");
switch (g_CurrentRegion)
case LORAMAC_REGION_AS923:
break;
case LORAMAC_REGION_AU915:
break;
case LORAMAC_REGION_CN470:
break;
case LORAMAC_REGION_EU433:
break;
case LORAMAC_REGION_IN865:
break;
case LORAMAC_REGION_EU868:
break;
case LORAMAC_REGION_KR920:
break;
case LORAMAC_REGION_US915:
break;
uint32_t err_code;
err_code = timers_init();
if (err_code != 0)
return;
// Setup the EUIs and Keys
if (doOTAA)
lmh_setDevEui(nodeDeviceEUI);
lmh_setAppEui(nodeAppEUI);
lmh_setAppKey(nodeAppKey);
else
lmh_setNwkSKey(nodeNwsKey);
lmh_setAppSKey(nodeAppsKey);
lmh_setDevAddr(nodeDevAddr);
// Initialize LoRaWan
err_code = lmh_init(&g_lora_callbacks, g_lora_param_init, doOTAA, g_CurrentClass, g_CurrentRegion);
lmh_setSubBandChannels(1);
if (err_code != 0)
return;
// Start Join procedure
lmh_join();
void loop() {
// put your main code here, to run repeatedly:
void preparePacket() {
Union a;
a.flt = flo;
Union b;
b.flt = flo;
int i = 0;
Lpacket[i++] = highByte(thingNum);
Lpacket[i++] = lowByte(thingNum);
Lpacket[i++] = appNum;
Lpacket[i++] = mac[0];
Lpacket[i++] = mac[1];
Lpacket[i++] = mac[2];
Lpacket[i++] = mac[3];
Lpacket[i++] = mac[4];
Lpacket[i++] = mac[5];
Lpacket[i++] = a.flBytes[0];
Lpacket[i++] = a.flBytes[1];
Lpacket[i++] = a.flBytes[2];
Lpacket[i++] = a.flBytes[3];
Lpacket[i++] = b.flBytes[0];
Lpacket[i++] = b.flBytes[1];
Lpacket[i++] = b.flBytes[2];
Lpacket[i++] = b.flBytes[3];
Lpacket[i++] = highByte(in);
Lpacket[i++] = lowByte(in);
Lpacket[i++] = bs;
if (ret == LMH_SUCCESS)
delay(1000);
TimerStart(&appTimer);
@param[in] app_data Pointer to rx data
m_lora_app_data.buffsize = 0;
lmh_send(&m_lora_app_data, g_CurrentConfirm);
//Not joined, try again later
return;
Union a;
a.flt = flo;
Union b;
b.flt = flo;
uint32_t i = 0;
m_lora_app_data.buffer[i++] = highByte(thingNum);
m_lora_app_data.buffer[i++] = lowByte(thingNum);
m_lora_app_data.buffer[i++] = appNum;
m_lora_app_data.buffer[i++] = mac[0];
m_lora_app_data.buffer[i++] = mac[1];
m_lora_app_data.buffer[i++] = mac[2];
m_lora_app_data.buffer[i++] = mac[3];
m_lora_app_data.buffer[i++] = mac[4];
m_lora_app_data.buffer[i++] = mac[5];
m_lora_app_data.buffer[i++] = a.flBytes[0];
m_lora_app_data.buffer[i++] = a.flBytes[1];
m_lora_app_data.buffer[i++] = a.flBytes[2];
m_lora_app_data.buffer[i++] = a.flBytes[3];
m_lora_app_data.buffer[i++] = b.flBytes[0];
m_lora_app_data.buffer[i++] = b.flBytes[1];
m_lora_app_data.buffer[i++] = b.flBytes[2];
m_lora_app_data.buffer[i++] = b.flBytes[3];
m_lora_app_data.buffer[i++] = highByte(in);
m_lora_app_data.buffer[i++] = lowByte(in);
m_lora_app_data.buffer[i++] = bs;
m_lora_app_data.buffsize = i;
if (error == LMH_SUCCESS)
count++;
else
count_fail++;
/**@brief Function for handling user timerout event.
send_lora_frame();
@details Initializes the timer module. This creates and starts application timers.
return 0;
I’ve tried changing the devaddr, nwskey, and appskey on both the node and gateway side to try to get the two sides to sync frame counters but to no avail. Any ideas?
