What product do you wish to discuss? RAK4631
What firmware are you using? Arduino BSP
Computer OS? Linux (Ubuntu)
How often does the problem happen? Everytime
How can we replicate the problem? Attempt to Write Japanese/Chinese characters to EPD
Provide source code if custom firmware is used or link to example if RAKwireless example code is used.
Hello all!
I am wondering if anyone has found a way to write Hiragana and Kanji to the RAK14000 E-Paper display? I have seen it done, but there is little to no info i can find on it. It seems like there would need
to be some sort of MASSIVE chip to store all of the character info.
Here is what I see when I attempt to write Hiragana:
@file RAK14000-Epaper-Monochrome.ino.ino
@author taylor.lee ([email protected])
@brief display image and text on DEPG0213BNS800F41HP/DEPG0213BNS800F42HP epaper,
and control by botton
@version 0.1
@date 2021-02-18
@copyright Copyright (c) 2021
#include <Arduino.h>
#include <Adafruit_GFX.h>
#include <Adafruit_EPD.h>
#include "images.h"
#define POWER_ENABLE WB_IO2
#define EPD_MOSI MOSI
#define EPD_MISO -1 // not use
#define EPD_SCK SCK
#define EPD_CS SS
#define EPD_DC WB_IO1
#define SRAM_CS -1 // not use
#define EPD_RESET -1 // not use
#define EPD_BUSY WB_IO4
#define LEFT_BUTTON WB_IO3
#define MIDDLE_BUTTON WB_IO5
#define RIGHT_BUTTON WB_IO6
/* Select the correct display from the defines below */
/* The display type is printed on the back of the */
/* display. */
/* If you use a different display than the one */
/* provided by RAKwireless you have to adjust the */
/* the values matching with your custom display */
typedef struct DEPG {
int width;
int height;
int position1_x;
int position1_y;
int position2_x;
int position2_y;
int position3_x;
int position3_y;
int position4_x;
int position4_y;
} DEPG;
DEPG DEPG_HP = {250,122,40,20,40,30,40,50,90,40}; //use DEPG0213BNS800F41HP as default
//DEPG DEPG_HP = {212,104,30,15,30,25,30,45,80,30}; // this is for DEPG0213BNS800F42HP
uint8_t gKeyNum = 2; // which button is pressed
// left button interrupt handle function
void interruptHandle1()
if(gKeyNum == 0)
gKeyNum = 1;
// middle button interrupt handle function
void interruptHandle2()
if(gKeyNum == 0)
gKeyNum = 2;
// right button interrupt handle function
void interruptHandle3()
if(gKeyNum == 0)
gKeyNum = 3;
// 2.13" EPD with SSD1680
Adafruit_SSD1680 display(DEPG_HP.width, DEPG_HP.height, EPD_MOSI,
EPD_SCK, EPD_DC, EPD_RESET,
EPD_CS, SRAM_CS, EPD_MISO,
EPD_BUSY);
void testdrawtext(int16_t x, int16_t y, char *text, uint16_t color);
@brief Arduino Setup function
void setup(void)
pinMode(POWER_ENABLE, INPUT_PULLUP);
digitalWrite(POWER_ENABLE, HIGH);
time_t timeout = millis();
while (!Serial)
delay(100);
else
break;
// set left button interrupt
pinMode(LEFT_BUTTON, INPUT);
attachInterrupt(LEFT_BUTTON, interruptHandle1, FALLING);
// set middle button interrupt
pinMode(MIDDLE_BUTTON, INPUT);
attachInterrupt(MIDDLE_BUTTON, interruptHandle2, FALLING);
// set right button interrupt
pinMode(RIGHT_BUTTON, INPUT);
attachInterrupt(RIGHT_BUTTON, interruptHandle3, FALLING);
Serial.println("EPD Epaper-DEPG0213BNS800F4xHP test");
display.begin();
// large block of text
display.clearBuffer();
display.drawBitmap(DEPG_HP.position1_x, DEPG_HP.position1_y, rak_img, 150, 56, EPD_BLACK);
testdrawtext(DEPG_HP.position1_x, DEPG_HP.position1_y+50, "IoT Made Easy", (uint16_t)EPD_BLACK, 2);
display.display(true);
@brief Arduino Loop function
void loop()
if(gKeyNum == 1)
Serial.println("Left button pressed");
display.drawBitmap(DEPG_HP.position2_x, DEPG_HP.position2_y, rak_img, 150, 56, EPD_BLACK);
gKeyNum = 0;
if(gKeyNum == 2)
Serial.println("Middle button pressed");
testdrawtext(DEPG_HP.position3_x, DEPG_HP.position3_y, "γγγ«γ‘γ―", (uint16_t)EPD_BLACK, 2);
gKeyNum = 0;
if(gKeyNum == 3)
Serial.println("Right button pressed");
display.drawBitmap(DEPG_HP.position4_x, DEPG_HP.position4_y, lora_img, 60, 40, EPD_BLACK);
gKeyNum = 0;
@brief Write a text on the display
@param x x position to start
@param y y position to start
@param text text to write
@param text_color color of text
@param text_size size of text
void testdrawtext(int16_t x, int16_t y, char *text, uint16_t text_color, uint32_t text_size)
display.setCursor(x, y);
display.setTextColor(text_color);
display.setTextSize(text_size);
display.setTextWrap(true);
display.print(text);
