Hi, I get at least 3 different Fail messages during JOIN procedure. Please, can you give more details about each message (meaning)?
RAK3172
Version: RUI_4.1.0_RAK3172-E
+EVT:JOIN_FAILED_RX_TIMEOUT
+EVT:JOIN_FAILED_6
+EVT:JOIN FAILED
RAK3172
+EVT:JOIN_FAILED_6
+EVT:JOIN FAILED
Hi @IGtti ,
The join errors indicate that there is no join accept received by the devices. If you want to troubleshoot why this happen, there errors wont give much help.
+EVT:JOIN_FAILED_RX_TIMEOUT - Both RX window didn’t receive join accept
+EVT:JOIN_FAILED_6 - RX2 window didn’t receive any join accept
+EVT:JOIN_FAILED - General error for failed join attempt
I am not sure why you get all this failed returns but it can be on the configuration of the device.
If you are solving a join related issue, these are the things you can look at:
In addition @IGtti , the RUI3 is now open source. You can check the full implementation of RAK3172 here - GitHub - RAKWireless/RAK-STM32-RUI: RUI3 BSP for RAK3172 modules
As for the error code _6, you can check it here - https://github.com/andrewpkent/RAK-STM32-RUI/blob/66772fa4d3921c811c79ad2b0e846a2215a18d7c/cores/STM32WLE/external/lora/LoRaMac-node-4.4.7/src/mac/LoRaMac.h#L376
I am not really familiar with the whole source code since this is developed by our RUI3 development team. But I try my best to navigate it. It is easy to check text and lines of code in Github to find stuff anyway.
Hi @carlrowan ,
I am writing my code and adding the ways for the exceptions. Initially I had only this error message: +EVT:JOIN_FAILED. Than, after changing some configuration in the device (on purpose) I got the other error messages… and decided to add/check them in the code as well.
Note: In the AT Commands documentation there is a missing caracter “_” in the message:
Thank you for the explanations.
Hi @IGtti ,
I tried different configuration on my device (adr, cfm, dcs, band) but I still can’t replicate your situation. I can copy your configurations if you can share me then I will check the AT replies.
Noted on the.docs.
Hi @carlrowan ,
I have a gateway, the different messages happened when I changed some configuration on the gateway.
The most important for me was to consider the different messagens in my device code.
Thanks again for the support.
