LA915-928A on RAK11310
I’m having problems connecting my device to the LoRaWAN network in Brazil, I ended up checking the band and found this value in the selected band, I wanted to know if there is any value that I can use in the wisblock RAK 11310 to make it work.
LoRaWAN region LA915 is not supported by the open source LoRaWAN library SX126x-Arduino.
Can you share the LoRaWAN regional specifications for LA915.
Here you can find the specification.
https://ns.docs.everynet.io/channel_plans/LA915A.html
I am also waiting for a new RUI3 release with this support!
RUI3 V4.1.0 supports LA915 ==> Releases
2 years later, some news about LA915.
The new Arduino library WisBlockLoRaWAN now supports LA915 region. This library is the successor of the SX126x-Arduino library with a bunch of updates:
  • LoRaWAN stack V1.0.4
  • Based on Sermtech LoRa Basics™ Modem
  • Supports Semtech LoRa transceivers SX1262, LR2021 and (work in progress) LR2012
  • Supports subGHz and 2.4GHz LoRa, 2.4Ghz only with the LR2021 transceiver, available on the soon to be released RAK13702 LoRa IO module
  • Supports LinkCheckRequest and TimeRequest MAC commands
  • Tested against Actility ThingPark with LA915 setup and RAK7268 gateway as LoRa Basics™ Station
Attention
Supports only WisBlock/WisDuo modules that are based on Arduino BSP/PlatformIO platforms. It does not support RUI3 based modules.
Supported Not supported
RAK4631/RAK4630 with Arduino bootloader RAK4631-R/RAK4630 with RUI3 bootloader
RAK3312/RAK3112 RAK3172
RAK11310/RAK11310 RAK11720
RAK3401 with Arduino bootloader RAK3401/RAK3400 with RUI bootloader
RAK11160/RAK11162
RAK11200 (ESP32-Wrover is EOL)
For RAK3401 without internal LoRa transceiver, the support includes IO modules with LoRa transceiver:
  • RAK13300 (SX1262 22dBm)
  • RAK13302 (SX1262 30dBm)
  • RAK13702 (LR2021 subGHz and 2.4GHz transceiver)
