As my battery voltage will be low (LTO) I will run on a single 3.3V supply. Could anyone confirm the latest power supply advice for low power consumption on single supply?
I also notice that the RAK4631 I currently have doesnt have the (external?) L10 fitted anyway and wondered if something in the designs changed.
In its default configuration yes but I’ve found by comparing the schematics it can be fairy easily modified to change the 0R links to match the single supply configuration. May be useful to others. Then you can power directly using the programming header.
