I am using a Davis Vantage Pro2 weather station sensor - Temp and Humidity
It is an SHT31-LS and the generic SHT libraries don’t work - it uses a Legacy Sensibus single shot output
I have had success with other boards using I2C where I can define the pins for the library - for the Wisblock, using the I2C on the base board I have been trying 19 - SDA and 20 - SCL
* ReadSHT31LS
* Read temperature and humidity values from an SHT31-LS
* May also work with the SHT1x series (SHT10, SHT11, SHT15) sensors.
* Copyright 2016 Alan Marchiori [email protected]
* www.hydrosense.net
#include <sensirion.h>
// Specify data and clock connections and instantiate sensirion object
#define dataPin 19
#define clockPin 20
#define ledPin 13
sensirion sht(dataPin, clockPin);
void setup()
Serial.begin(9600); // Open serial connection to report values to host
Serial.println("Starting up");
pinMode(ledPin, OUTPUT);
void loop()
float temp_c;
float temp_f;
float humidity;
// blink
digitalWrite(ledPin, (digitalRead(ledPin) == HIGH) ^ 1);
if (1){
uint16_t status = sht.readStatus();
Serial.print("Status: 0x"); Serial.println(status, HEX);
if (1){
humidity = sht.readHumidity();
Serial.print("Humidity: "); Serial.print(humidity); Serial.println("%");
if (1){
temp_c = sht.readTemperatureC();
Serial.print("Temperature: "); Serial.print(temp_c, DEC); Serial.println(" C");
if (1){
temp_f = sht.readTemperatureF();
Serial.print("Temperature: "); Serial.print(temp_f, DEC); Serial.println(" F");
delay(2000);
Is there anything else I could be trying?
thanks in advance
