what could cause the messages to fail
I start the application i get 2 good messages then after that all i get is lmh_send fail messages over and over my loop
any ideas?
any ideas?
@buton
Region?
Payload size?
ADR enabled or disabled?
What code? One of our example codes or your own code?
I did a Mix of copy paste, Region US915, DR0, ADR ON
Here is some sample code.
* @file LoRaWAN_OTAA_ABP.ino
* @author rakwireless.com
* @brief LoRaWan node example with OTAA/ABP registration
* @version 0.1
* @date 2020-08-21
* @copyright Copyright (c) 2020
* @note RAK4631 GPIO mapping to nRF52840 GPIO ports
RAK4631 <-> nRF52840
WB_IO1 <-> P0.17 (GPIO 17)
WB_IO2 <-> P1.02 (GPIO 34)
WB_IO3 <-> P0.21 (GPIO 21)
WB_IO4 <-> P0.04 (GPIO 4)
WB_IO5 <-> P0.09 (GPIO 9)
WB_IO6 <-> P0.10 (GPIO 10)
WB_SW1 <-> P0.01 (GPIO 1)
WB_A0 <-> P0.04/AIN2 (AnalogIn A2)
WB_A1 <-> P0.31/AIN7 (AnalogIn A7)
#include <Arduino.h>
#include <SPI.h>
#include <TinyGPS.h> //http://librarymanager/All#TinyGPS
#include <Wire.h>
#include <U8g2lib.h> // Click to install library: http://librarymanager/All#u8g2
//--- Oled Display
//U8G2_SSD1306_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0);
U8G2_SSD1306_128X32_UNIVISION_F_HW_I2C u8g2(U8G2_R0);
//GPS stuff
TinyGPS gps;
unsigned long fix_age;
String tmp_data = "";
int direction_S_N = 0; //0--S, 1--N
int direction_E_W = 0; //0--E, 1--W
bool start_gps = false;
bool lora_joined=false;
int Led1_Blink=0;
int Led2_Blink=0;
int timing1=0;
int timing2=0;
// RAK4630 supply two LED
#ifndef LED_BUILTIN
#define LED_BUILTIN 35
#endif
#ifndef LED_BUILTIN2
#define LED_BUILTIN2 36
#endif
#define LORAWAN_DATERATE DR_0 /*LoRaMac datarates definition, from DR_0 to DR_5*/
#define LORAWAN_TX_POWER TX_POWER_5 /*LoRaMac tx power definition, from TX_POWER_0 to TX_POWER_15*/
DeviceClass_t g_CurrentClass = CLASS_A; /* class definition*/
LoRaMacRegion_t g_CurrentRegion = LORAMAC_REGION_US915; /* Region:EU868*/
lmh_confirm g_CurrentConfirm = LMH_UNCONFIRMED_MSG; /* confirm/unconfirm packet definition*/
//---Lora Config STUFF
static lmh_param_t g_lora_param_init = {LORAWAN_ADR_ON, LORAWAN_DATERATE, LORAWAN_PUBLIC_NETWORK, JOINREQ_NBTRIALS, LORAWAN_TX_POWER, LORAWAN_DUTYCYCLE_OFF};
// Foward declaration
//void direction_parse(String tmp)
static lmh_callback_t g_lora_callbacks = {BoardGetBatteryLevel, BoardGetUniqueId, BoardGetRandomSeed,
lorawan_rx_handler, lorawan_has_joined_handler, lorawan_confirm_class_handler, lorawan_join_failed_handler
//OTAA keys !!!! KEYS ARE MSB !!!!
uint8_t nodeDeviceEUI[8] =x
uint8_t nodeAppEUI[8] = x
uint8_t nodeAppKey[16] =x
// ABP keys
uint32_t nodeDevAddr = x
uint8_t nodeNwsKey[16] = x
uint8_t nodeAppsKey[16] = x
// Private defination
#define LORAWAN_APP_INTERVAL 20000 /**< Defines for user timer, the application data transmission interval. 20s, value in [ms]. */
static uint32_t count = 0;
char data[32] = {0};
if (tmp.indexOf(",E,") != -1)
direction_E_W = 0;
else
direction_E_W = 1;
if (tmp.indexOf(",S,") != -1)
direction_S_N = 0;
else
direction_S_N = 1;
void setup() {
//put your setup code here, to run once:
pinMode(LED_BUILTIN, OUTPUT);
pinMode(LED_BUILTIN2, OUTPUT);
//-- Init Display
u8g2.begin();
time_t timeout = millis();
while (!Serial)
delay(100);
else
break;
u8g2.clearBuffer(); // clear the internal memory
u8g2.setFont(u8g2_font_6x13_tf); // choose a suitable font
delay(300);
//--Display Init
memset(data, 0, sizeof(data));
sprintf(data, "Init");
u8g2.drawStr(0, 15, data);
// Initialize LoRa chip.
lora_rak4630_init();
if (doOTAA)
Serial.println("Type: OTAA");
else
Serial.println("Type: ABP");
switch (g_CurrentRegion)
case LORAMAC_REGION_AS923:
break;
case LORAMAC_REGION_AU915:
break;
case LORAMAC_REGION_CN470:
break;
case LORAMAC_REGION_CN779:
Serial.println("Region: CN779");
break;
case LORAMAC_REGION_EU433:
break;
case LORAMAC_REGION_IN865:
break;
case LORAMAC_REGION_EU868:
break;
case LORAMAC_REGION_KR920:
break;
case LORAMAC_REGION_US915:
break;
case LORAMAC_REGION_RU864:
Serial.println("Region: RU864");
break;
case LORAMAC_REGION_AS923_2:
Serial.println("Region: AS923-2");
break;
case LORAMAC_REGION_AS923_3:
Serial.println("Region: AS923-3");
break;
case LORAMAC_REGION_AS923_4:
Serial.println("Region: AS923-4");
break;
uint32_t err_code;
// Setup the EUIs and Keys
if (doOTAA)
lmh_setDevEui(nodeDeviceEUI);
lmh_setAppEui(nodeAppEUI);
lmh_setAppKey(nodeAppKey);
else
lmh_setNwkSKey(nodeNwsKey);
lmh_setAppSKey(nodeAppsKey);
lmh_setDevAddr(nodeDevAddr);
// Initialize LoRaWan
err_code = lmh_init(&g_lora_callbacks, g_lora_param_init, doOTAA, g_CurrentClass, g_CurrentRegion);
if (err_code != 0)
return;
// Start Join procedure
lmh_join();
//gps init
pinMode(WB_IO2, OUTPUT);
digitalWrite(WB_IO2, 0);
delay(1000);
digitalWrite(WB_IO2, 1);
delay(1000);
Serial1.begin(9600);
while (!Serial1);
Serial.println("gps uart init ok!");
timing1=millis();
timing2=millis();
void loop() {
//--Upadte Display
u8g2.sendBuffer(); // transfer internal memory to the display
//-- LED Blinking changes
if( (millis()-timing1)>Led1_Blink)
digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
timing1=millis();
if( (millis()-timing2)>Led2_Blink)
digitalWrite(LED_BUILTIN2, !digitalRead(LED_BUILTIN2));
timing2=millis();
//-- Start GPS flag for troubleshooting
start_gps=true;//-- leaving it true for now
//-- Enter GPS once we joined a lora network
if(start_gps&&lora_joined)
Serial.println("entering GPs...");
bool newData = false;
// For one second we parse GPS data and report some key values
sprintf(data, "*");
u8g2.drawStr(30, 30, data);
for (unsigned long start = millis(); millis() - start < 1000;)
while (Serial1.available())
Led2_Blink=200;
char c = Serial1.read();
//Serial.write(c); // uncomment this line if you want to see the GPS data flowing
tmp_data += c;
if (gps.encode(c))// Did a new valid sentence come in?
newData = true;
else
//--- Erase *
u8g2.setColorIndex(0);
u8g2.drawBox(30, 15, 60,30);
u8g2.setColorIndex(1);
//-- Set to - to make it kind of blink
sprintf(data, "-");
delay(500);
direction_parse(tmp_data);
tmp_data = "";
float flat, flon;
int32_t ilat, ilon;
//-- If new data is valid we decode
if (newData)
Serial.println("Got GPS Fix");
//-- Indicator on display that we go t a fix
sprintf(data, "F-Y");
u8g2.drawStr(0, 30, data);
unsigned long age;
gps.f_get_position(&flat, &flon, &age);
flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flat;
ilat = flat * 100000;
flon == TinyGPS::GPS_INVALID_F_ANGLE ? 0.0 : flon;
ilon = flon * 100000;
//-- Display GPS Data on Display
sprintf(data,"%0.2f %0.2f",flat,flon);
u8g2.drawStr(50,30, data);
//-- Set lora buffer
m_lora_app_data.buffer[0] = 0x09;
//lat data
m_lora_app_data.buffer[1] = (ilat & 0xFF000000) >> 24;
m_lora_app_data.buffer[2] = (ilat & 0x00FF0000) >> 16;
m_lora_app_data.buffer[3] = (ilat & 0x0000FF00) >> 8;
m_lora_app_data.buffer[4] = ilat & 0x000000FF;
if(direction_S_N == 0)
m_lora_app_data.buffer[5] = 'S';
else
m_lora_app_data.buffer[5] = 'N';
//lon data
m_lora_app_data.buffer[6] = (ilon & 0xFF000000) >> 24;
m_lora_app_data.buffer[7] = (ilon & 0x00FF0000) >> 16;
m_lora_app_data.buffer[8] = (ilon & 0x0000FF00) >> 8;
m_lora_app_data.buffer[9] = ilon & 0x000000FF;
if(direction_E_W == 0)
m_lora_app_data.buffer[10] = 'E';
else
m_lora_app_data.buffer[10] = 'W';
m_lora_app_data.buffsize = 11;
send_lora_frame();
digitalWrite(LED_BUILTIN2,HIGH);
delay(20000);
/**@brief LoRa function for handling HasJoined event.
//--Delete Init Message
u8g2.drawBox(1, 1, 40,15);
//-- Show Network Joined on display
sprintf(data, "N-%s","J");
Led1_Blink=1000;
if (ret == LMH_SUCCESS)
delay(1000);
lora_joined=true;
//-- Failed To Join display message
sprintf(data, "N-%s","X");
Led1_Blink=300;
* @param[in] app_data Pointer to rx data
m_lora_app_data.buffsize = 0;
lmh_send(&m_lora_app_data, g_CurrentConfirm);
Serial.write("entering send lora frame");
//Not joined, try again later
return;
if (error == LMH_SUCCESS)
count++;
//-- Display Count
sprintf(data, "M: Tx %d",count);
u8g2.drawStr(30, 15, data);
else
count_fail++;
//--Display fail count
sprintf(data, "Ftx- %d",count_fail);
u8g2.drawStr(80, 15, data);
Hi @buton
Can you try to switch ADR off by setting LORAWAN_ADR_OFF in g_lora_param_init?
static lmh_param_t g_lora_param_init = {LORAWAN_ADR_OFF, LORAWAN_DATERATE, LORAWAN_PUBLIC_NETWORK, JOINREQ_NBTRIALS, LORAWAN_TX_POWER, LORAWAN_DUTYCYCLE_OFF};
And datarate of DR0 on US915 is the smallest allowed package size (11 bytes). It should fit with your data package, but maybe you better try with DR1.
#define LORAWAN_DATERATE DR_1 /*LoRaMac datarates definition, from DR_0 to DR_5*/
You can find package sizes per region per datarate in our Documentation Center
Do you have access to the gateway? If yes, can you get the log file from the gateway showing the data transmission?
@buton , it is most likely caused by the DR set to 0. Especially, if you are too close to the gateway
