I have a Wisblock with a 4631 as the core, but also an NB IoT module attached.
Do I need to still have the lora antenna attached if not using lora at all?
I know with some modules the transceiver can be damaged without it connected.
Hi Paul,
as long as you do not activate LoRa it is safe. Same for BLE. No need to use antenna unless you initialize them.
