I just received my first LoRa Button LB801. When I connect it to my PC via USB, using the Linux minicom, speed to 115200 and I can receive the message when I press a button longer than 5 seconds. However, when I try to type any “at+” command, I get no feedback nor response from the commands.
What am I doing wrong? How can I use Linux minicom to setup my button?
Thanks Fomi. The problem is that your device expect a CR/LF as line end and Linux minicom only sends a CR. Using CuteCom we can set it to send both CR/LF as line end. Just for record, the device runs at 115200 bauds, 8 bits, no parity, 1 stop bit.
