Good morning,
The join process is done with success, but after that, nothing happen. Take a look below:
This is the console log:
Blockquote
RAK4630 Console
CLEAR
10:54
AT+VER=RUI_4.1.0_RAK4631
10:54
OK
10:57
DISCONNECTED
10:57
RECONNECTED
10:57
AT+NWM=1
10:57
OK
10:57
AT+NWM=1
10:57
OK
10:57
AT+NJM=1
10:57
OK
10:57
AT+BAND=6
10:57
OK
10:57
AT+APPEUI=AC1F09FF00000001
10:57
OK
10:57
AT+APPKEY=4B4170706C69636174696F6E204B6579
10:57
OK
10:57
AT+APPSKEY=D67A0444B4E3930B854DA240BBCEFC3F
10:57
OK
10:57
AT+DEVADDR=260B71D5
10:57
OK
10:57
AT+DEVEUI=AC1F09FFFE0CE7F6
10:57
OK
10:57
AT+NETID=000013
10:57
OK
10:57
AT+NWKSKEY=4337D9150BBFD41311C966EEF25BF1AC
10:57
OK
10:57
AT+CFM=1
10:57
OK
10:57
AT+CFS=0
10:57
OK
10:57
AT+JOIN=1:1:8:0
10:57
OK
10:57
AT_COMMAND_NOT_FOUND
10:57
[SCAN] Found sensor on I2C1 0x18
10:57
[SCAN] Found sensor on I2C1 0x42
10:57
[GNSS] RAK12500 found on I2C
10:57
[GNSS] Rate 1
10:57
AT+NJS=1
10:57
OK
10:57
AT+RECV=0:
10:57
OK
10:57
10:57
[AT_CMD] GNSS 4 digit Cayenne LPP
10:57
[SETUP] RAKwireless RUI3 Location Tracker Node
10:57
[SETUP] Setup LoRaWAN credentials with AT commands
10:57
[SETUP] Then start join with AT+JOIN=1:1
10:57
[SETUP] Custom AT command Success
10:57
[MOD] +EVT:RAK12500 OK
10:57
Current Work Mode: LoRaWAN.
10:57
AT+ADR=0
10:57
OK
10:57
AT+CLASS=A
10:57
OK
10:57
AT+DCS=1
10:57
OK
10:57
AT+DR=3
10:57
OK
10:57
AT+PNM=1
10:57
OK
10:57
AT+JN1DL=5
10:57
OK
10:57
AT+RX1DL=5
10:57
OK
10:57
AT+JN2DL=6
10:57
OK
10:57
AT+RX2DL=2
10:57
OK
10:57
AT+RX2DR=8
10:57
OK
10:57
AT+RX2FQ=923300000
10:57
OK
10:57
AT+TXP=0
10:57
OK
10:57
AT+PGSLOT=0
10:57
OK
10:57
AT_NO_CLASSB_ENABLE
10:57
AT_NO_CLASSB_ENABLE
10:57
AT_NO_CLASSB_ENABLE
10:57
AT+LTIME=00h00m01s on 01/01/1970
10:57
OK
10:57
10:57
AT+CHS=0
10:57
OK
10:57
AT+CHE=1
10:57
OK
10:57
10:57
AT+ARSSI=0:0,1:0,2:0,3:0,4:0,5:0,6:0,7:0,64:0
10:57
OK
10:57
10:57
AT+LINKCHECK=0
10:57
OK
10:57
AT+RETY=0
10:57
OK
10:57
AT+TIMEREQ=0
10:57
OK
10:57
0:00000000:00000000000000000000000000000000:00000000000000000000000000000000:000000000:00:0,0:00000000:00000000000000000000000000000000:00000000000000000000000000000000:000000000:00:0,0:00000000:00000000000000000000000000000000:00000000000000000000000000000000:000000000:00:0,0:00000000:00000000000000000000000000000000:00000000000000000000000000000000:000000000:00:0
10:57
OK
10:57
10:57
10:57
AT+LPM=0
10:57
OK
10:57
10:57
10:57
10:57
10:58
AT+BUILDTIME=20231208-231949
10:58
OK
10:58
AT+CLIVER=1.5.11
10:58
OK
10:58
AT+ALIAS=
10:58
OK
10:58
OK
10:58
ATC+GNSS=4 digit Cayenne LPP
10:58
OK
10:58
ATC+SENDFREQ=0s
10:58
OK
10:58
Device Status:
10:58
Module: RAK4630
10:58
Version: RUI_4.0.6_RAK4631
10:58
Send time: 0 s
10:58
Network mode LoRaWAN
10:58
Network joined
10:58
Region: 6
10:58
Region: AU915
10:58
OTAA mode
10:58
DevEUI = AC1F09FFFE0CE7F6
10:58
AppEUI = AC1F09FF00000001
10:58
AppKey = 4B4170706C69636174696F6E204B6579
10:58
OK
