Good morning @beegee
I am creating my code to work the WisBlock configurations:
- LPWAN module: to send the sensors information to LNS → TagoIO
- Environment module: temperature and humidity
- 4-20ma interface: analog sensors
- 0-5V interface: analog sensors
I am developing the code step-by-step, in the complexity. I mean, I already created three libraries:
A serial initialization: to clean the main.cpp
A LEDs initialization: to clean the main.cpp
A LoRa initialization: to clean the main.
If it is possible, I would like your help. My problem is that as you can see in the section “Messages on the monitor” and “The Things Stack device page”, the main.cpp finish with LoRaWAN join sucessfull by The Things Stack log, without error messages, but no LoRaWAN join successful message in the WisBlock.
Maybe I am wrong, but I was expecting to join message in the WisBlock console. Anyway, I would like to have status message. What you recomend?
Blockquote
Main.cpp
- @file RAK1906-1903-LoRa-01
- @author Claudio Rosa
- @brief LoRaWan node example with OTAA registration
- @brief Setup and read values from a BME680 environment sensor using the BOSCH BSEC library
- @version 0.1
- @date 2021-02-18
- @copyright Copyright (c) 2021
- @note RAK5005-O GPIO mapping to RAK4631 GPIO ports
- IO1 ↔ P0.17 (Arduino GPIO number 17)
- IO2 ↔ P1.02 (Arduino GPIO number 34)
- IO3 ↔ P0.21 (Arduino GPIO number 21)
- IO4 ↔ P0.04 (Arduino GPIO number 4)
- IO5 ↔ P0.09 (Arduino GPIO number 9)
- IO6 ↔ P0.10 (Arduino GPIO number 10)
- SW1 ↔ P0.01 (Arduino GPIO number 1)
- LED1 ↔ P1.03 (Arduino GPIO number 35)
- LED2 ↔ P1.04 (Arduino GPIO number 36)
/ ************** Libraries *************************** */
#include <Arduino.h>
#include <SPI.h>
#include <bsec.h> //http://librarymanager/All#BSEC_BME680 */
#include <Wire.h>
#include <SerialInit.h> //private libray to initialize and test Serial/Monitor Communications */
#include <LEDsInit.h> //private library to initialize and test the LEDs Green and Blue
#include <LoRaInit.h> //private library to initialize and test the LoRa Radio
// RAK4630 supply three LEDs
int RecPinG = 35, RecPinB = 36;
/* *********************** LoRa definitions *************************** /
String RecRegion = “AU915”;
int RecSubBand = 2;
/ ****************** Configuration Function ****************** */
void setup()
// Initialize USB Serial for debug output
SerialInterface USB1(UPLOAD_SPEED,MONITOR_SPEED);
USB1.SerialInit();
// LEDs inialization
LEDsInterface LED(RecPinG, RecPinB);
LED.LEDsInit();
/* ************ LoRa Startup Procedures ******************* */
LoRaRadio Radio1(RecRegion, RecSubBand);
Radio1.LoRaInit();
void loop()
/* ****** Radio Events ********** /
// Handle Radio events
Radio.IrqProcess();
Blockquote
Blockquote
Executing task in folder RAK1906-1903-LoRa-01: C:\Users\Claudio Rosa.platformio\penv\Scripts\pio.exe device monitor <
- Available filters and text transformations: colorize, debug, default, direct, hexlify, log2file, nocontrol, printable, send_on_enter, time
- More details at Redirecting...
- Miniterm on COM15 115200,8,N,1 —
- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H —
= Error 10 to initialize USB port
= USB port initialized width 115200 baud.
= Monitor port intialized width 115200 baud.
======= work fine in setup section =========
LED GREEN PIN=35=> OFF
LED BLUE PIN=36=> OFF
LED GREEN PIN=35=> ON
LED BLUE PIN=36=> ON
= LEDS GREEN and BLUE initialized and OFF
Welcome to RAK4630 LoRaWan!!!
Type: OTAA
LoRa Region: AU915
Blockquote
Blockquote
LoRaInit.h
- Lib name: LoRaInit.h
- purpose : create a clear vision in the code when all LoRa Radio inialization routine is move to this lib
- author : Claudio Rosa
- contact : https://www.linkedin.com/in/claudio-rosa-aa71a418
- date : 16/02/2021
#ifndef LoRa_ini
#define LoRa_ini
class LoRaRadio
private:
String Region;
int SubBand;
public:
LoRaRadio( String RecRegion,int RecSubBand);
int getInitParams();
void setInitParams( String RecRegion,int RecSubBand);
void LoRaInit();
#endif
Blockquote
Blockquote
LoRaInit.cpp
Lib name: LoRaInitInit.h
purpose : create a clear vision in the code when all serial interface inialization routine is move to this lib
date : 17/02/2021
bool doOTAA = true;
#define LORAWAN_DATERATE DR_0 /LoRaMac datarates definition, from DR_0 to DR_5/
#define LORAWAN_TX_POWER TX_POWER_5 /LoRaMac tx power definition, from TX_POWER_0 to TX_POWER_15/
DeviceClass_t gCurrentClass = CLASS_A; /* class definition*/
lmh_confirm gCurrentConfirm = LMH_CONFIRMED_MSG; /* confirm/unconfirm packet definition*/
/* @brief Structure containing LoRaWan parameters, needed for lmh_init() */
static lmh_param_t lora_param_init = {LORAWAN_ADR_ON, LORAWAN_DATERATE, LORAWAN_PUBLIC_NETWORK, JOINREQ_NBTRIALS, LORAWAN_TX_POWER, LORAWAN_DUTYCYCLE_OFF};
// Foward declaration
/**@brief Structure containing LoRaWan callback functions, needed for lmh_init() */
static lmh_callback_t lora_callbacks = {BoardGetBatteryLevel, BoardGetUniqueId, BoardGetRandomSeed,
lorawan_rx_handler, lorawan_has_joined_handler, lorawan_confirm_class_handler};
//OTAA keys !!! KEYS ARE MSB !!!
uint8_t nodeDeviceEUI[8] = { 0xAC, 0x1F, 0x09, 0xFF, 0xFE, 0x03, 0xB9, 0xBE };
uint8_t nodeAppEUI[8] = { 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01 };
uint8_t nodeAppKey[16] = { 0xC2, 0x02, 0x2D, 0xC3, 0xE8, 0xB2, 0x2A, 0x02, 0xDE, 0xDC, 0x8C, 0x7A, 0xC0, 0xF6, 0xFD, 0x30 };
// Private defination
#define LORAWAN_APP_INTERVAL 20000 /**< Defines for user timer, the application data transmission interval. 20s, value in [ms]. */
TimerEvent_t appTimer;
static uint32_t count = 0;
LoRaRadio::LoRaRadio( String RecRegion, int RecSubBand )
setInitParams(RecRegion, RecSubBand);
void LoRaRadio::setInitParams( String RecRegion, int RecSubBand )
Region = RecRegion;
SubBand = RecSubBand;
int LoRaRadio::getInitParams()
return Region, SubBand;
void LoRaRadio::LoRaInit()
// Initialize LoRa chip.
lora_rak4630_init();
Serial.println("Type: OTAA");
#if defined(REGION_AS923)
Serial.println("LoRa Region: AS923");
#elif defined(REGION_AU915)
Serial.println("LoRa Region: AU915");
#elif defined(REGION_CN470)
Serial.println("LoRa Region: CN470");
#elif defined(REGION_CN779)
Serial.println("LoRa Region: CN779");
#elif defined(REGION_EU433)
Serial.println("LoRa Region: EU433");
#elif defined(REGION_IN865)
Serial.println("LoRa Region: IN865");
#elif defined(REGION_EU868)
Serial.println("LoRa Region: EU868");
#elif defined(REGION_KR920)
Serial.println("LoRa Region: KR920");
#elif defined(REGION_US915)
Serial.println("LoRa Region: US915");
#elif defined(REGION_US915_HYBRID)
Serial.println("LoRa Region: US915_HYBRID");
#else
Serial.println("Please define a region in the compiler options.");
#endif
//create a user timer to send data to server period
uint32_t err_code;
err_code = timers_init();
if (err_code != 0)
else {
// Setup the EUIs and Keys
lmh_setDevEui(nodeDeviceEUI);
lmh_setAppEui(nodeAppEUI);
lmh_setAppKey(nodeAppKey);
// Initialize LoRaWan
err_code = lmh_init(&lora_callbacks, lora_param_init, doOTAA);
if (err_code != 0)
// Start Join procedure
lmh_join();
lmh_error_status ret = lmh_class_request(gCurrentClass);
if (ret == LMH_SUCCESS)
delay(1000);
TimerStart(&appTimer);
/* @brief Function for handling LoRaWan received data from Gateway
@param[in] app_data Pointer to rx data
m_lora_app_data.buffsize = 0;
lmh_send(&m_lora_app_data, gCurrentConfirm);
//Not joined, try again later
return;
uint32_t i = 0;
m_lora_app_data.buffer[i++] = 'H';
m_lora_app_data.buffer[i++] = 'e';
m_lora_app_data.buffer[i++] = 'l';
m_lora_app_data.buffer[i++] = 'o';
m_lora_app_data.buffer[i++] = '!';
m_lora_app_data.buffsize = i;
lmh_error_status error = lmh_send(&m_lora_app_data, gCurrentConfirm);
if (error == LMH_SUCCESS)
count++;
else
count_fail++;
/@brief Function for handling user timerout event./
send_lora_frame();
@details Initializes the timer module. This creates and starts application timers. */
return 0;
Blockquote
