Hello
On using sensors with LoRa I would like to ask something that seems impossible to overcome:
Response time on a very narrow bandwidth structure should be slow and not able to reply to, for example, alarm sensors which vice versa do need immediate alerts
Is there an estimate of response time over a LoRa network?
thanks
If you are using Lorawan, there are air-time calculators online that you can use to have an initial estimate. Something like this https://www.loratools.nl/#/airtime
But you need to test it in actual setup to see if the response time that you get, is the one you need.
That’s very nice
a confirmation of what I thought
thanks a lot
