I’m getting this message in the logs
Mon Jun 13 19:36:54 2022 daemon.notice netifd: wwan (6871): udhcpc (v1.23.2) started
Mon Jun 13 19:36:54 2022 user.notice hotplug: Cannot find LORA usb proper mapping, exit
Mon Jun 13 19:36:54 2022 daemon.notice netifd: wwan (6871): Sending discover...
Mon Jun 13 19:36:54 2022 user.notice hotplug: Symlink from /dev/ttyUSB3 to /dev/ttyATWWAN created
Mon Jun 13 19:36:54 2022 user.err basicstation[2361]: [GPS:ERRO] NMEA checksum error: FFFFFFFF vs 61
Mon Jun 13 19:36:57 2022 daemon.notice netifd: wwan (6871): Sending discover...
Mon Jun 13 19:37:00 2022 daemon.notice netifd: wwan (6871): Sending discover...
Mon Jun 13 19:37:05 2022 kern.info quectel-CM[6465]: Find /sys/bus/usb/devices/1-1.1 idVendor=2c7c idProduct=0195
Mon Jun 13 19:37:05 2022 kern.info quectel-CM[6465]: Find /sys/bus/usb/devices/1-1.1:1.4/net/wwan0
Mon Jun 13 19:37:05 2022 kern.info quectel-CM[6465]: Find usbnet_adapter = wwan0
Mon Jun 13 19:37:05 2022 kern.info quectel-CM[6465]: Find /sys/bus/usb/devices/1-1.1:1.4/usbmisc/cdc-wdm0
Mon Jun 13 19:37:05 2022 kern.info quectel-CM[6465]: Find qmichannel = /dev/cdc-wdm0
Mon Jun 13 19:37:05 2022 kern.info quectel-CM[6465]: cdc_wdm_fd = 7
Mon Jun 13 19:37:05 2022 kern.info quectel-CM[6465]: Get clientWDS = 20
Mon Jun 13 19:37:05 2022 kern.info quectel-CM[6465]: Get clientDMS = 1
Mon Jun 13 19:37:05 2022 kern.info quectel-CM[6465]: Get clientNAS = 4
Mon Jun 13 19:37:05 2022 kern.info quectel-CM[6465]: Get clientUIM = 1
Mon Jun 13 19:37:05 2022 kern.info quectel-CM[6465]: Get clientWDA = 1
Mon Jun 13 19:37:05 2022 kern.info quectel-CM[6465]: requestBaseBandVersion EG95NAFBR05A04M4G
Mon Jun 13 19:37:05 2022 kern.info quectel-CM[6465]: requestGetSIMStatus SIMStatus: SIM_ABSENT
Mon Jun 13 19:37:05 2022 kern.info quectel-CM[6465]: requestGetProfile[1] ///0
Mon Jun 13 19:37:05 2022 kern.info quectel-CM[6465]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jun 13 19:37:05 2022 kern.info quectel-CM[6465]: requestQueryDataCall IPv4ConnectionStatus: DISCONNECTED
Mon Jun 13 19:37:05 2022 kern.info quectel-CM[6465]: Dail Failed 1
Mon Jun 13 19:37:10 2022 kern.info quectel-CM[6465]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jun 13 19:37:10 2022 kern.info quectel-CM[6465]: Dail Failed 2
Mon Jun 13 19:37:16 2022 kern.info quectel-CM[6465]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jun 13 19:37:16 2022 kern.info quectel-CM[6465]: Dail Failed 3
Mon Jun 13 19:37:21 2022 kern.info quectel-CM[6465]: requestRegistrationState2 MCC: 0, MNC: 0, PS: Detached, DataCap: UNKNOW
Mon Jun 13 19:37:21 2022 kern.info quectel-CM[6465]: Dail Failed 4
Then the Dail Failed message repeats with every 10 messages another
Mon Jun 13 19:44:38 2022 user.notice data-broker: [16] Client mosq-UGvKAhlph2VSVQWtxM sending PINGREQ
Mon Jun 13 19:44:38 2022 user.notice data-broker: [16] Client mosq-UGvKAhlph2VSVQWtxM received PINGRESP
The main Status tab shows the LoRa Network Server isn’t running.
Is there a test I can run to see if this is a hardware issue or if it’s a configuration problem? 2 days ago I was receiving LoRa packets and they were appearing on the LoRa Packet Logger, All I’ve tried is rebooting the device to try to resolve this.
