LoRaMAC busy is thrown when you do an API call but there is
- an TX/RX cycle still ongoing
- the device is trying to join the network and you send another command, e.g. setting the DevEUI or trying to send a packet
There might be a view more cases, but these are the usual ones.
What do you mean with “Fix it”?
If TX is active, the device is either (1) trying to join the network or it is (2) in a TX/RX cycle.
(1) can be started automatically, if you set autojoin with AT+JOIN=1:1 before. This is saved in flash, so on every reboot the device will try to join, independent of any API call. You can get the result of the join attempt with the API Join callback function
(2) Wait for the TX/RX cycle to be finished. Best is to use the API TX callback function.
* @brief Callback after join request cycle
* @param status Join result
if (status != 0)
MYLOG("JOIN-CB", "LoRaWan OTAA - join fail! \r\n");
// To be checked if this makes sense
// api.lorawan.join();
else
MYLOG("JOIN-CB", "LoRaWan OTAA - joined! \r\n");
digitalWrite(LED_BLUE, LOW);
* @brief LoRaWAN callback after TX is finished
* @param status TX status
MYLOG("TX-CB", "TX status %d", status);
tx_active = false;
* @brief LoRaWAN callback after packet was received
* @param data pointer to structure with the received data
void receiveCallback(SERVICE_LORA_RECEIVE_T *data)
MYLOG("RX-CB", "RX, port %d, DR %d, RSSI %d, SNR %d", data->Port, data->RxDatarate, data->Rssi, data->Snr);
for (int i = 0; i < data->BufferSize; i++)
Serial.printf("%02X", data->Buffer[i]);
Serial.print("\r\n");
tx_active = false;
void setup()
// Setup the callbacks for joined and send finished
api.lorawan.registerRecvCallback(receiveCallback);
// ..... do other setup stuff
