Is there a limit for the numer of bytes that can be sent at once? whenever I try a number bigger than 10, there will be some kind of error. Either there will be an error with the TTS server o I will receive the lmh_send fail count message at the terminal. Could you help me please? I’m using the Rak4630 board and the tts server with a whitebelt webhook.
#include <Arduino.h>
#include <bluefruit.h>
#include <SPI.h>
//Aquí viene la parte de LoRa
// RAK4630 supply two LED
#ifndef LED_BUILTIN
#define LED_BUILTIN 35
#endif
#ifndef LED_BUILTIN2
#define LED_BUILTIN2 36
#endif
// TODO: Set this to your LoRaWAN Region
LoRaMacRegion_t g_CurrentRegion = LORAMAC_REGION_US915;
// Set to true to select Over-The-Air Activation (OTAA), false for Activation By Personalisation (ABP)
bool doOTAA = true;
//OTAA keys !!! KEYS ARE MSB !!!
uint8_t nodeDeviceEUI[8] = {XXXXX};
uint8_t nodeAppEUI[8] = {XXXXXX};
uint8_t nodeAppKey[16] = {XXXXXX};
// ABP keys
uint32_t nodeDevAddr = XXXX;
uint8_t nodeNwsKey[16] = {XXXXXX};
uint8_t nodeAppsKey[16] = {XXXXXX};
#define LORAWAN_DATERATE DR_0 /LoRaMac datarates definition, from DR_0 to DR_5/
#define LORAWAN_TX_POWER TX_POWER_5 /LoRaMac tx power definition, from TX_POWER_0 to TX_POWER_15/
DeviceClass_t g_CurrentClass = CLASS_A; /* class definition*/
lmh_confirm g_CurrentConfirm = LMH_UNCONFIRMED_MSG; /* confirm/unconfirm packet definition*/
static lmh_param_t g_lora_param_init = {
LORAWAN_ADR_ON,
LORAWAN_DATERATE,
LORAWAN_PUBLIC_NETWORK,
JOINREQ_NBTRIALS,
LORAWAN_TX_POWER,
LORAWAN_DUTYCYCLE_OFF
// Foward declaration
static lmh_callback_t g_lora_callbacks = {
BoardGetBatteryLevel,
BoardGetUniqueId,
BoardGetRandomSeed,
lorawan_rx_handler,
lorawan_has_joined_handler,
lorawan_confirm_class_handler,
// Private defination
#define LORAWAN_APP_INTERVAL 20000 /**< Defines for user timer, the application data transmission interval. .5s, value in [ms]. */
TimerEvent_t appTimer;
static uint32_t count = 0;
//variables globales
int i;//contador para ciclos for, principalmente el que recorre el arreglo de dispositivos
int j;//variable para los índices del arreglo de bytes que es el mensaje
int largo_mensaje;//esta variable sirve para decirle al send_message cuando detenerse
byte mensaje[12];//Aquí es donde guardamos el contenido del packet que vamos a mandar por LoRa
//Es necesario guardar varios datos de los dispositivos, así que se guardan en esta estructura
int no_dispositivos=2;//El número de dispositivos que vamos a usar
lmh_app_data_t *datitos;/estructura necesaria para recoger los downlinks/
struct BLE_device{
byte MAC[6]; //Aquí se guarda la dirección MAC
unsigned long previous_millis=0UL;
unsigned long interval=1000UL;
byte clave[2]; /* Esta variable es para asignarle una clave que nos ayude a identificar
los diferentes dispositivos que estamos usando*/
bool current_bandera=false;
bool previous_bandera=false;
// When we have joined the LoRaWAN network, start a 20-second timer
Serial.println(“OTAA Mode, Network Joined!”);
if (ret == LMH_SUCCESS)
delay(1000);
TimerStart(&appTimer);
// If we can’t join the LoRaWAN network, show the error
Serial.println(“OTAA join failed!”);
Serial.println(“Check your EUI’s and Keys’s!”);
Serial.println(“Check if a Gateway is in range!”);
@param[in] app_data Pointer to rx data
bool compara(byte trama_1[], byte trama_2[], uint8_t ind_1, uint8_t ind_2)
bool coincide = true;
for (int i = 0; i < 6 && coincide; i++)
if (trama_1[i + ind_1] != trama_2[ind_2 + i])
coincide = false;
return coincide;
// When we receive a LoRaWAN Packet from the LoRaWAN Gateway, display it.
// TODO: Ensure that app_data->buffer is null-terminated.
/*se supone que esta función void forma parte de una estructura formada por
todos los callbacks que hay para este código. Están en un arreglo que sirve
como parámetro para el lora_init.
byte down_packet[] = {0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x72, 0x01,
0x00, 0x00,0x30, 0x14, 0x00, 0x20, 0x00, 0x00, 0x00, 0x00, 0x00,
0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00};
if(compara(down_packet,app_data->buffer,0,0)==false)
{Serial.printf("LoRa Packet received on port %d, size:%d, rssi:%d, snr:%d, data:%s\n",
Serial.printBuffer(app_data->buffer,'-');
Serial.println();
// Callback Function that is called when the LoRaWAN Class has been changed
Serial.printf(“switch to class %c done\n”, “ABC”[Class]);
m_lora_app_data.buffsize = 0;
lmh_send(&m_lora_app_data, g_CurrentConfirm);
// This is called when the 20-second timer expires. We send a LoRaWAN Packet.
// Not joined, try again later
return;
for(i=0;i<largo_mensaje;i++){
m_lora_app_data.buffer[i]=mensaje[i];
m_lora_app_data.buffsize = largo_mensaje;
// Transmit the LoRaWAN Packet
if (error == LMH_SUCCESS)
count++;
else
count_fail++;
/**@brief Function for handling user timerout event.
// When the 20-second timer has expired, send a LoRaWAN Packet and restart the timer
Serial.println(“Sending frame now…”);
send_lora_frame();
@details Initializes the timer module. This creates and starts application timers.
return 0;
// At startup, we join the LoRaWAN network, in either OTAA or ABP mode
//Aquí viene la parte del BLE
void cargar_direccion(byte destino[6],byte sexto, byte quinto,byte cuarto,byte tercero, byte segundo,byte primero)
destino[0]= sexto;
destino[1]= quinto;
destino[2]= cuarto;
destino[3]= tercero;
destino[4]= segundo;
destino[5]= primero;
void configurar_dipositivo(BLE_device dispositivo,byte sexto, byte quinto,byte cuarto,byte tercero, byte segundo,byte primero,byte unidad, char tipo);
void scan_callback(ble_gap_evt_adv_report_t* report)
//variables de la función del callback
BLE_device dispositivo;/arreglo de dispositivos BLE integrados/
/*configurar los dispositivos
cargar las direcciones*/
cargar_direccion(dispositivo.MAC,0xDD,0xDD,0xE7,0x3F,0x23,0xAC);//MBM01 unidad 01
// configurar las claves.
//MBM01
//unidad 01
dispositivo.clave[0]=0xA7;
dispositivo.clave[1]=0x01;
//Scouteamos para encontrar payloads de las MAC que están en el arreglo
if(compara( report->peer_addr.addr,dispositivo.MAC,0,0)==true)
Serial.printBufferReverse(report->peer_addr.addr, 6, ':');
Serial.println(" ");
for(j=0;j<10;j++)
mensaje[j]=0x00;
mensaje[j++]=dispositivo.clave[0];
mensaje[j++]=dispositivo.clave[1];
largo_mensaje=j;
Bluefruit.Scanner.resume();
void setup()
{//setup de Lora
pinMode(LED_BUILTIN, OUTPUT);
// Initialize LoRa chip.
lora_rak4630_init();
while ( !Serial ) delay(10); // for nrf52840 with native usb
Serial.println(“Welcome to RAK4630 LoRaWan!!!”);
if (doOTAA)
Serial.println("Type: OTAA");
else
Serial.println("Type: ABP");
switch (g_CurrentRegion)
case LORAMAC_REGION_AS923:
break;
case LORAMAC_REGION_AU915:
break;
case LORAMAC_REGION_CN470:
break;
case LORAMAC_REGION_EU433:
break;
case LORAMAC_REGION_IN865:
break;
case LORAMAC_REGION_EU868:
break;
case LORAMAC_REGION_KR920:
break;
case LORAMAC_REGION_US915:
break;
uint32_t err_code;
err_code = timers_init();
if (err_code != 0)
return;
// Setup the EUIs and Keys
if (doOTAA)
lmh_setDevEui(nodeDeviceEUI);
lmh_setAppEui(nodeAppEUI);
lmh_setAppKey(nodeAppKey);
else
lmh_setNwkSKey(nodeNwsKey);
lmh_setAppSKey(nodeAppsKey);
lmh_setDevAddr(nodeDevAddr);
// Initialize LoRaWaN
err_code = lmh_init( // lmh_init now takes 3 parameters instead of 5
&g_lora_callbacks, // Callbacks
g_lora_param_init, // Functions
doOTAA, // Set to true for OTAA
g_CurrentClass, // Class
g_CurrentRegion // Region
if (err_code != 0)
return;
// Start Join procedure
Serial.println(“Joining LoRaWAN network…”);
lmh_join();
//Setup de BLE
Serial.println(“Bluefruit52 Central Scan Example”);
Serial.println("--------------------------------\n");
// Initialize Bluefruit with maximum connections as Peripheral = 0, Central = 1
// SRAM usage required by SoftDevice will increase dramatically with number of connections
Bluefruit.begin(0, 1);
Bluefruit.setTxPower(4); // Check bluefruit.h for supported values
Bluefruit.setName(“Bluefruit52”);
// Start Central Scan
Bluefruit.setConnLedInterval(250);
Bluefruit.Scanner.setRxCallback(scan_callback);
Bluefruit.Scanner.start(0);
Serial.println(“Scanning …”);
void loop()
lorawan_rx_handler(datitos);
