Low Power for Wisblock development
  • What product do you wish to discuss? RAK4631
  • What firmware are you using? Arduino BSP
  • Computer OS? Windows
  • What Computer OS version? 11 Pro
I am developing a Wisblock solution with:
  1. RAK4631
  2. RAK19007
  3. RAK1904
  4. RAK1906
  5. RAK 12500
After I am measuring with Nordic Power Profile Kit II, when the minimum power consuming that I get when manually disable until UART, it is 2 mA. I am not finding what is consuming.
I am expecting to maintain in “sleep mode” it is some µA for 15 minutes and after that wakeup to make its tasks.
Could you help me to find what I have to make to a real sleep mode?
Regards,
Claudio
Without seeing your code, it is impossible to say what is happening.
Some ideas:
(1) how is RAK1904 setup? Power consumption depends on sample rate and there is a trick to set it into low power mode:
	// Enable high pass filter
	acc_sensor.writeRegister(LIS3DH_CTRL_REG2, 0x01);
	// Set low power mode
	data_to_write = 0;
	acc_sensor.readRegister(&data_to_write, LIS3DH_CTRL_REG1);
	data_to_write |= 0x08;
	acc_sensor.writeRegister(LIS3DH_CTRL_REG1, data_to_write);
	delay(100);
	data_to_write = 0;
	acc_sensor.readRegister(&data_to_write, 0x1E);
	data_to_write |= 0x90;
	acc_sensor.writeRegister(0x1E, data_to_write);
	delay(100);
(2) RAK1906, did you enable or disable the heater of the sensor? If you set automatic measurement and the heater is on, it leads to higher consumption.
(3) RAK12500, what is your setup? What is your measurement rate, navigation frequency, did you enable power save mode? Do you power it down when not in use?
(4) RAK4631, I get lowest power consumption when stopping the loop() by using semaphores to wake it up by events (timers, interrupts, …)
Do you have a low power code examples for each sensor?
I know it is not the best option but I am using to sleep for 15 minutes: SensorGNSS.powerOff(900000);
I splited with one library for each wisblock sensor:
For the RAK12500 example:
RAK12500.cpp
void IniciaRAK12500()
   // Incia RAK12500 GNSS sensor
	pinMode(WB_IO2, OUTPUT);
	digitalWrite(WB_IO2, 0);
	vTaskDelay(pdMS_TO_TICKS(1000));
	digitalWrite(WB_IO2, 1);
	if (CFG_DEBUG >= D_INFORMA) {
		Serial.println("============  Iniciando o RAK12500 via I2C ============");
		Serial.println("=======================================================");
	do  //testa se o sensor está conectado
		count2++;
		if (SensorGNSS.begin() == false)
					if (CFG_DEBUG != 0) {
						Serial.print("Não detectado o u-blox GNSS no endereço padrão. Verifique as conexões. Tentativa ");
						Serial.print(String(count2));
						Serial.println(". Tentando outra vez!");
	} while(((SensorGNSS.begin()) == false) & (count2<11));
		Serial.println("=========== RA12500 inciado com sucesso ===============");
	// SensorGNSS.setNavigationFrequency(1); // Set the update rate to 1Hz
	// Habilita o modo de economia de energia
	// SensorGNSS.powerSaveMode(true);
void LeGNSS()
		// Le via GNSS a geo-localização
		Serial.println("============= Geo-localização =========================");
	count2=0;
			count2++;
				if (CFG_DEBUG >= D_ERRO) {
					Serial.print("Não foi detectado o u-blox GNSS no endereço padrão. Verifique as conexões. Tentativa ");
		} while((SensorGNSS.begin() == false) & (count2<11));
	if (SensorGNSS.begin() != false) { //Connect to the u-blox module using Wire port
		if (millis() - g_lastTime > 1000)
				g_lastTime = millis(); //Update the timer
				// Data e hora
				RAK12500.UNIXEpoch	 = SensorGNSS.getUnixEpoch(); // Recebe o horário no formato UNIX
				// Posição
				RAK12500.Latitude = SensorGNSS.getLatitude();
				RAK12500.Longitude = SensorGNSS.getLongitude();
				RAK12500.Altitude = SensorGNSS.getAltitude(); // Altitude em metros
				RAK12500.Acuracia = SensorGNSS.getHorizontalDOP() / 100.0;
				RAK12500.Velocidade = SensorGNSS.getGroundSpeed()/100.0;
				RAK12500.Direcao = SensorGNSS.getHeading()/100000.0;
				RAK12500.sats = SensorGNSS.getSIV();
					Serial.printf(" tempo em operação: %d\n",g_lastTime);
					Serial.printf(" tamanho de UNIXEpoch: %d\n",sizeof(RAK12500.UNIXEpoch));
					Serial.printf(" tamanho de Lat: %d\n",sizeof(RAK12500.Latitude));
					Serial.printf(" tamanho de Long: %d\n",sizeof(RAK12500.Longitude));
					Serial.printf(" tamanho de Alt: %d\n",sizeof(RAK12500.Altitude));
					Serial.printf("Inteiros Lat: %d Lon: %d \n", RAK12500.Latitude, RAK12500.Longitude);
					Serial.printf("Inteira Alt: %d M \n", RAK12500.Altitude);
					Serial.printf(" UNIXEpoch: %d\n", RAK12500.UNIXEpoch);
					Serial.printf("Lat: %9.6f Lon: %9.6f", RAK12500.Latitude / 10000000.0, RAK12500.Longitude/ 10000000.0);
					Serial.printf(" Alt: %5.2f M \n", RAK12500.Altitude / 1000.0);
					Serial.printf(" Acuracia: %3.2f %%\n", RAK12500.Acuracia);
					Serial.printf(" Velocidade: %4.1f m/s \n", RAK12500.Velocidade);
					Serial.printf(" Direção: %4.1f graus \n", RAK12500.Direcao);
					Serial.printf(" Satélites: %3d\n", RAK12500.sats);
					vTaskDelay(pdMS_TO_TICKS(5000));
				// Modo de economia de energia
				SensorGNSS.powerOff(900000); // Turn off the GNSS module
RAK12500.h
#ifndef _RAK12500_H
#define _RAK12500_H
// Bibliotecas personalizadas
// Bibliotecas do Firmware
// RAK12500 GNSS
#include <SparkFun_u-blox_GNSS_Arduino_Library.h> //http://librarymanager/All#SparkFun_u-blox_GNSS
#include <iomanip>
void Acorda();
void IniciaRAK12500();
void LeGNSS();
struct GeoLocalizacao
    public:
    uint32_t UNIXEpoch = 0;    // horário no formato UNIX
    long Latitude      = 0;    // latitude em graus
    long Longitude     = 0;    // Longitude em graus
    int16_t Altitude   = 0;    // Altitude em metros
    int32_t Acuracia   = 0;    // índice de precisão
    int16_t HDop       = 0;    // dispersão horizontal
    int32_t Velocidade = 0;    // Velocidade em m/s
    int32_t Direcao    = 0;    // Direção em graus
    byte sats          = 0;    // número de satélites
} RAK12500;
SFE_UBLOX_GNSS SensorGNSS;
double g_lastTime = 0; //Simple local timer. Limits amount if I2C traffic to u-blox module.
uint8_t count2=0;
#endif
It is a terrible large proof-of-concept project that I made some time ago. It covers most WisBlock sensors:
WisBlock-Sensor-For-LoRaWAN
Thank you by your support.
Regards,
Cláudio
I saw in your example a configuration, as:
AT+GNSS
Where this configuration is implemented?
Is it in the RUI3? I mean: Does RUI3 has support for all my Wisblock sensor by AT commands?
Does RUI3 has support for VSCode/PlatformIO?
The example is using my WisBlock-API-V2, which is close to RUI3, but it is for the open source Arduino BSP’s and is for nRF52 (RAK4631), ESP32 (RAK11200) and RP2040 (RAK11310).
It
  • supports 99% of the RUI3 commands to setup the device
  • like RUI3 includes the handling of
    • LoRa P2P
    • LoRaWAN
    • BLE
It is designed for low power consumption, e.g. there is no loop(), every thing is handled with semaphores.
Timers or external events like interrupts can wake-up the device with the g_task_event_type flag.
Some of these events are handled by WisBlock-API-V2, but the user can define his own events. They are handled in the app_event_handler();, where the user includes his event handlers.
Using this requires a re-thinking if you are used to Arduino setup() and loop(). They are no longer available.
You can find more information in the README
Claudio
