to familiarize myself with EndDevice RAK7205 I did the Burning Bootloader into the Device and Upgrading the Firmware procedures.
Before doing so I sent the AT command at+set_config=device:restart
LoRa (R) is a registered trademark or service mark of Semtech Corporation or its affiliates. LoRaWAN (R) is a licensed mark.
______ ___ _ __ _ _ _ _
| ___ \/ _ \ | | / / | | | (_) | |
| |_/ / /_\ \| |/ / | | | |_ _ __ ___| | ___ ___ ___
| /| _ || \ | |/\| | | '__/ _ \ |/ _ \/ __/ __|
| |\ \| | | || |\ \ \ /\ / | | | __/ | __/\__ \__ \
\_| \_\_| |_/\_| \_/ \/ \/|_|_| \___|_|\___||___/___/
RAK5205 Version:3.0.0.14.H.beta4
The version was: RAK5205 Version:3.0.0.14.H.beta4
After the procedures described in RAK Documentation Center:
RAK5205 Version:3.0.0.12.H.T1
The version is: RAK5205 Version:3.0.0.12.H.T1, I took a downgrade!!!
Questions:
- I need to update RAK811 board core? If the answer is yes as I should do.
- Perhaps for point 1 the concept is described by @Fomi in Altitude incorrect RAK 5205 firmware 3.0.0.6
- After updating the firmware
DevEuiis set at343737306B398014instead ofAppEuiandAppKeythey arezeros.DevEuiis reported on the chip/label. Where can I findAppEuiandAppKey?
Thank you for your attention
cm
