What product do you wish to discuss? RAK4631, RAK3372, RAK11200, RAK11310, RAK11722?
- RAK19007 Base Board
- RAK13800 Ethernet-Module
- RAK19018 PoE Board
- RAK12500 GPS
- RAK4631 LoRa Core Module
What firmware are you using? (RUI3 or Arduino BSP or other IDE (e.g. STM32CubeIDE)?
meshtastic -
What firmware version? Can it be obtained with AT+VER=?
firmware-rak4631-2.3.6.7a3570a
firmware-rak4631-2.3.10.d19607b -
Computer OS? (MacOS, Linux, Windows)
Linux -
What Computer OS version?
Fedora 27 -
How often does the problem happen?
Every ~30minutes -
How can we replicate the problem?
Hook up these nodes and flash one of these meshtastic releases -
Provide source code if custom firmware is used or link to example if RAKwireless example code is used.
INFO | 21:37:57 902 [Button] Shutdown from long press
INFO | 21:38:00 905 [Button] Shutting down
INFO | 21:38:00 905 [Button] Entering deep sleep forever
INFO | 21:38:00 905 [Button] Disable NRF52 bluetooth
DEBUG | 21:38:00 905 [Button] SX126x entering sleep mode (FIXME, don't keep config)
DEBUG | 21:38:00 905 [Button] Completed sending (id=0x48df96cb fr=0xaf to=0xff, WantAck=0, HopLim=3 Ch=0x8 encrypted rxtime=1716845876 hopStart=3 priority=64)
INFO | 21:38:00 905 [Button] GPS deep sleep!
INFO | 21:38:00 905 [Button] Saving /prefs/db.proto
INFO | 21:38:03 908 [Button] Saving /prefs/config.proto
INFO | 21:38:05 910 [Button] Saving /prefs/module.proto
INFO | 21:38:07 912 [Button] Saving /prefs/channels.proto
INFO | 21:38:09 914 [Button] Setting GPS power=0
DEBUG | 21:38:09 914 [Button] Sleep Time: 0
