I am interested in using the RAK3172 in a device that would eventually require FCC/CE/etc. certification. My interpretation is that the RAK3172 has attained these certifications and can be treated as a pre-certified RF module. I believe that this means the following:
- The end device that implements the RAK3172 may use an antenna with the following specs:
- dipole antenna connected via IPEX connector
- 2.3 dBi max gain
The end device will be in compliance with the modular certification if the RUI3 API is used.
The end device must undergo non-intentional radiator certification but will not need to repeat intentional radiator certification provided points 1 and 2 above are met.
Any insights into this topic would be very helpful, especially in the context of RAK devices.
Thanks!
