Hi everyone, I am using the RAK13800 - Ethernet Module WIZnet W5100S-L and RAK4631 (main core) to connect to Mosquitto MQTT broker as a client, but I amd getting continuously disconnect and reconnect. I tried to configure the keepalive but it doesn’t seems to work properly.
I should mention that I also use a UWB module and both are working on a dual base IO RAK19011. Only I use the UWB to get the distance between devices and then sends to the broker.
Is anyone there knows to fix the issue?
