I’m trying to configure the RAK7249 using the internal Build-In Server but with the MQTT gateway bridge active.
If I route the Packet Forwarder dircetly to the Build-In Server, all is OK. The join procedure succeed and I receive “application/+/…” on my MQTT client.
But when I route the Packet Forwarder to the MQTT Bridge (internal), I can see the “gateway/+/…” topics on my MQTT client, I see the “application/+/join” and the associated “gateway/+/rx”, but the Build-In Lora server never respond to the gateway with the join ack.
I try this conf because I need to send some special messages directly to the gateway through the MQTT bridge.
Anybody has already try this configuration ?
Thanks in advance,
Julien
