Issue:
I want to have multiple frequencies working, but not at the same time. I want to select a frequency and turn on the right gateway.
Setup:
two 2247, one 868mhz one 43mhz.
Server:
chirpstack loraserver
Details:
Issue:
Setup:
Server:
Details:
Are you sure both bands are meaningfully usable under the regulations in your location?
Typically it would make more sense to have one embedded computer per concentrator.
Are you using SPI or USB concentators?
Hei @momo232030 ,
As @cstratton said, what hardware exactly are you running the concentrators on?
The two bands are pretty far apart, so you will not only need 2 concetrators but also 2 antennas. What benefit exactly are you seeking in running this setups as opposed to 2 separate gateways?
Vladislav
