Issue:
can’t ping anything anymore, worked fine for a couple of days but stopped after that.
Setup:
Server: Chirpstack
Details:
Issue:
Setup:
Server: Chirpstack
Details:
When you used it normally before, whether the cable and LTE were online at the same time? The problem I saw was that when you directly ping, everything was normal. When you specified ppp0 to ping instruction, there would be an error.
the cable and lte was on the same time, now with cable i can only ping google.com with lte i can’t ping anything
Try the following and let us get more detailed information:
"sudo gateway-config" command, select "Disable LTE Automatic Dial-up", and restart the gateway.
"sudo pppd call grps" shows that after dialing successfully, open another terminal and ssh to log in to the gateway, use the command "ifconfig" to view information about ppp0.My email: [email protected]
I have received your email.
The IP address of ppp0 is strange. It is more like a LAN IP.
Have you tried replacing another sim card?
