What product do you wish to discuss? RAK4631
What firmware are you using? VSCode/PlatformIO
What firmware version?
Computer OS? (MacOS, Linux, Windows) Windows
What Computer OS version? Windows 11
How often does the problem happen? Always
How can we replicate the problem? Yes
Provide source code if custom firmware is used or link to example if RAKwireless example code is used.
Good morning,
I did a @beegee code mix, based on the examples that RAKWIRELESS had in the Github, to work with RAK4631, RAK1904, RAK1906 and RAK12500, installed in a Base board RAK19007.
I had installed in a RAK19007 Base board: slot A a RAK1904(Accelerometer), slot B a RAK1906(Environment) and slot D a RAK12500(GNSS). With this configuration I had no contact/answer from RAK12500 in slot D.
I change for: : slot A a RAK12500(GNSS) , slot B a RAK1906(Environment) and slot D a RAK1904(Accelerometer) . Now I have contact/answer from RAK12500.
I already did a conflict check with WisBlock-IO-Pin-Mapper spreadsheet, and no problems with both configurations.
May be it is a mechanical problem in the slot D connector. Any ideas?
Cláudio
