Issue: I cannot get valid GPS location when I run the lora_pkt_fwd gateway for a helium hotspot
Setup: https://store.rakwireless.com/products/rak-discover-kit-2
Server:
Raspberry Pi 4 Model B Rev 1.2
PRETTY_NAME="Debian GNU/Linux 10 (buster)"
NAME="Debian GNU/Linux"
VERSION_ID="10"
VERSION="10 (buster)"
Raspberry Pi reference 2020-08-20
Generated using pi-gen, https://github.com/RPi-Distro/pi-gen, 7252c154838ec5b4576f29c996ac8fe3750cae12, stage2
Linux raspberrypi 5.4.51-v8+ #1333 SMP PREEMPT Mon Aug 10 16:58:35 BST 2020 aarch64 GNU/Linux
Revision : b03112
Serial : 1000000063593f07
Model : Raspberry Pi 4 Model B Rev 1.2
Details:
I purchased the Rak 2 discover kit and performed the following setup on it.
Installed the Pi OS 64 bit lite image
http://downloads.raspberrypi.org/raspios_lite_arm64/images/on a 16GB flash card. -
Ran
raspi-configto enable\disable the following:
- Select `Interfacing Options`
- Select `SPI`
- Select `Yes`
- Select `IC2`
- Select `Yes`
- Select `Serial Communictioans`
- Select `No` for shell access
- Select `Yes` for serial port hardware
- Select `Yes` to confirm
- Set hostname if desired
- Save changes and reboot by selecting `Finish`
- Installed and compiled the
SX1302 LoRa Gateway projectfrom source, using this repo:
- Ran the ./lora_pkt_fwd and see the following messages, even though my device is under clear sky. (note that the global_config.json is pointing to /dev/ttyS0):
gateway_1 | ### [GPS] ###
gateway_1 | # Valid time reference (age: 1 sec)
gateway_1 | # no valid GPS coordinates available yet
Debugging.
I originally tried /dev/ttyAMA0, but saw no data there. When I switched to use /dev/ttyS0, I would see some NMEA data if I cat’d the socket. However, as soon as I started the forwarder, it would start printing binary data on the socket. The only thing that would reset it back to what looked like NMEA data, was powering off the Pi and restarting it.
I also am not sure what pins I should use to reset the RAK2287. Currently I am using…
SX1302_RESET_PIN=17
SX1302_POWER_EN_PIN=2
Any help debugging is much appreciated.
