Issue: Node Joined Getting Denied
Setup: MSP432 - RN2903 and RAK7258
LoRa® Server: Built-in Lora Server
Details: I recently got a new RAK7258 and started with the basic LoRaWAN transmission. I set up the device in the application tab and generated the appkey. Use those credentials to send over the RN2903. I can see the JSON string of Join request coming up in the system log and also in the Live Device Data tab, it logs the Join request.
But some reason the node shows denied and connection doesn’t happen. I’ve checked the channel plan and kept the server private. In network settings, everything is used as default with ADR ON. I’ve checked the DevEui, AppEUI and AppKey numerous times to be sure. Not sure what else to check here.
I’d appreciate any help/leads that can help me debug this issue.
Thanks in advance.
