Issue:Arduino mkr 1310 will not join with the RAK7258
Setup: Using the arduino LoraSendAndRecieve and connecting to TTN
LoRa® Server: TTN
Details:
My RAK7258 is registered and connected successfully to TTN.
I have the Application and MKR1310 device registered on TTN.
My MKR1310 will not join to the RAK7258 using this code:
modem.joinOTAA(appEui, appKey)
The above statement just hangs.
I dont see anything in the RAK system log that indicates a join.
Mon Jan 4 14:59:07 2021 user.notice lora_pkt_fwd[16406]:
2021-01-04 21:59:07 UTC
Mon Jan 4 14:59:07 2021 user.notice lora_pkt_fwd[16406]: ### [UPSTREAM] ###
Mon Jan 4 14:59:07 2021 user.notice lora_pkt_fwd[16406]: # RF packets received by concentrator: 0
Mon Jan 4 14:59:07 2021 user.notice lora_pkt_fwd[16406]: # CRC_OK: 0.00, CRC_FAIL: 0.00, NO_CRC: 0.00
Mon Jan 4 14:59:07 2021 user.notice lora_pkt_fwd[16406]: # RF packets forwarded: 0 (0 bytes)
Mon Jan 4 14:59:07 2021 user.notice lora_pkt_fwd[16406]: # PUSH_DATA datagrams sent: 1 (135 bytes)
Mon Jan 4 14:59:07 2021 user.notice lora_pkt_fwd[16406]: # PUSH_DATA acknowledged: 100.00
Mon Jan 4 14:59:07 2021 user.notice lora_pkt_fwd[16406]: ### [DOWNSTREAM] ###
Mon Jan 4 14:59:07 2021 user.notice lora_pkt_fwd[16406]: # PULL_DATA sent: 6 (100.00 acknowledged)
Mon Jan 4 14:59:07 2021 user.notice lora_pkt_fwd[16406]: # PULL_RESP(onse) datagrams received: 0 (0 bytes)
Mon Jan 4 14:59:07 2021 user.notice lora_pkt_fwd[16406]: # RF packets sent to concentrator: 0 (0 bytes)
Mon Jan 4 14:59:07 2021 user.notice lora_pkt_fwd[16406]: # BEACON queued: 0
Mon Jan 4 14:59:07 2021 user.notice lora_pkt_fwd[16406]: # BEACON sent so far: 0
Mon Jan 4 14:59:07 2021 user.notice lora_pkt_fwd[16406]: # BEACON rejected: 0
Mon Jan 4 14:59:07 2021 user.notice lora_pkt_fwd[16406]: ### [JIT] ###
Mon Jan 4 14:59:07 2021 user.notice lora_pkt_fwd[16406]: # SX1301/SX1302 time (PPS): 2799208518, offset us 0
Mon Jan 4 14:59:07 2021 user.notice lora_pkt_fwd[16406]: ### [GPS] ###
Mon Jan 4 14:59:07 2021 user.notice lora_pkt_fwd[16406]: # GPS sync is disabled
Mon Jan 4 14:59:07 2021 user.notice lora_pkt_fwd[16406]: ##### END #####
Any ideas?
