Issue:Not getting valid GPS location, only getting empty NMEA strings on /dev/ttyAMA0
Setup: https://store.rakwireless.com/products/rak-discover-kit-2?variant=39945702473926
Server:
Raspberry Pi 4 Model B Rev 1.2
Rak2287 + Pi_Hat
OS - Ubuntu 20.04.4 LTS
Details:
- Installed the Pi OS 64 bit lite image
http://downloads.raspberrypi.org/raspios_lite_arm64/images/on a 16GB flash card. - Ran
raspi-configto enable\disable the following:
- Select
Interfacing Options- Select
SPI - Select
Yes
- Select
- Select
IC2 - Select
Yes
- Select
- Select
Serial Communictioans - Select
Nofor shell access - Select
Yesfor serial port hardware - Select
Yesto confirm
- Select
- Save changes and reboot by selecting
Finish- https://github.com/RAKWireless/rak_common_for_gateway
- go to rak_gateway directory then installed install.sh script.
- while installing selected 7 number option (7.RAK7248 no LTE (RAK2287 SPI + raspberry pi))
- after installation ran ‘sudo gateway-config’
- select ‘setup rak gateway lora concentrator’
- select ‘Network is chirpstack’
- select ‘select channel plan’
- select ‘IN 865 - 867’
- select ‘server ip’ - ok
- select ‘chirpstack ADR configuration’
- select ‘Enable ADR’
on rak_terminal run ‘cat /dev/ttyAMA0’
output: empty NMEA strings
pi@rak-gateway:~ $ cat /dev/ttyAMA0
7A
�b Xg�����$GNRMC,N2E
$GNGGA,GNGSA,A,1,99SA,A,1,99.991,1,0079
$GLGSV,1,1,00
�b @k$GNRMC,0,00,99.99,GNGSA,A,992E
1,1,007V,1,1,0099,99.992E
�b (o�����$GNRMC,N2E
$GNGGA,9.99,GNGSA,A,9,99.992E
$GNGSA,A,1,9.992E
$GPGSV,1,1,007GLL,V,N7A
V,1,1,0065,00,99.99,99.99,99.99,99.99*,99.99,99.99,99.992E
$GNGLL,v������$GNRMC,N2E
$GNGGA,GNGSA,A,99.99,99.99,99.992E
$GNGSA,A,1,99.99,99.99,99.992E
$GPGSV,1,1,007V,1,1,0065
$GNGLL,V,N7A
,N2E,N4D
1,1,007GLL,V,N7A,GNGSA,A,999,99.99SA,A,1,99.999.992E
1,1,007V,1,1,00GLL,999,99.99SA,A,1,99.999.992E
�b ��$GNRMC,N4D
$GNVTG,N2E
$GNGGA,9.99,GNGSA,A,999,99.99SA,A,1,99.999.992E
$GPGSV,1,1,0079
$GLGSV,1,1,00GLL,V,N7A
�b ��,N4D
$GNVTG,9.99,56
$GNGSA,A,9,99.992E
$GNGSA,A,1,9.992E
$GNGLL,V,N7A
$GNRMC,V,N4D
$GNVTG,NGGA,0,00,99.99,56
$GNGSA,A,99.99,99.99,99.992E
$GNGLL,V,N7A
1,1,0079,0,00,99.99,GNGSA,A,1,99.99,99.99,99.99SA,A,1,99.99,99.99,99.992E
$GLGSV,1,1,0065
$GNGLL,
N2E�����=$GNRMC,N4D
$GPGSV,1,1,0079
$GLGSV,1,1,00GLL,
,NGGA,9.99,GNGSA,A,.99,99.99,99.99SA,A,1,99.991,1,0079
$GLGSV,1,1,00
�b ������$GNRMC,N2E
$GLGSV,1,1,00GLL,�����H$GNRMC,N2E
$GLGSV,1,1,00
�b �������$GNRMC,N*4D
problem: GPS coordinates are incorrect only getting empty nmea strings.
