网关RAK7258,完全相同配置的两个Lorawan终端,向网关发送数据,1个能正常收到application数据,1个不能收到应用层数据,只能在lora packet logger看到日志。
网关已经设置 Disable Frame-counter Validate。不知道模组的问题还是网关设置的问题?
通讯失败的包日志
Sun Dec 15 20:54:50 2024 user.err wisdm[24293]: Shadow Connection Error
Sun Dec 15 20:54:51 2024 daemon.info gwBridge[1918]: gwBridgeReadCB: Frame size 12
Sun Dec 15 20:54:51 2024 daemon.info gwBridge[1918]: Enter gwBridgeFrameRcv, mdCreateEvent 0 Frame Len 12
Sun Dec 15 20:54:51 2024 daemon.info gwBridge[1918]: Uplink Packet from Gateway ac1f09fffe015f5e
Sun Dec 15 20:54:51 2024 user.info lora_pkt_fwd[2084]: INFO: [down] PULL_ACK received in 1 ms
Sun Dec 15 20:54:52 2024 user.debug lora_pkt_fwd[2084]: rrd_statistic_up 367 uplinkTqByAirtime : dr = 3, timeonair = 185, tm = 1734267292
Sun Dec 15 20:54:52 2024 user.debug lora_pkt_fwd[2084]: rrd_statistic_up 369 uplinkTqByPkt : dr = 3, tm = 1734267292
Sun Dec 15 20:54:52 2024 user.debug lora_pkt_fwd[2084]: rrd_statistic_up 371 ChanBusyByAirtime chan 4, timeonair = 185, tm = 1734267292
Sun Dec 15 20:54:52 2024 user.debug lora_pkt_fwd[2084]: Uplink Frame :
Sun Dec 15 20:54:52 2024 user.debug lora_pkt_fwd[2084]: 40 DB 25 01 26 00 F0 51
Sun Dec 15 20:54:52 2024 user.debug lora_pkt_fwd[2084]: 03 7C 35 39 2F D0 6D 6D
Sun Dec 15 20:54:52 2024 user.debug lora_pkt_fwd[2084]: 61 44 A3 F7 23 89 DA
Sun Dec 15 20:54:52 2024 user.info lora_pkt_fwd[2084]: JSON up: {“rxpk”:[{“tmst”:1858284340,“chan”:4,“rfch”:0,“freq”:486.300000,“stat”:1,“modu”:“LORA”,“datr”:“SF9BW125”,“codr”:“4/5”,“lsnr”:11.5,“rssi”:-80,“size”:23,“data”:“QNslASYA8FEDfDU5L9BtbWFEo/cjido=”}]}
Sun Dec 15 20:54:52 2024 daemon.info gwBridge[1918]: gwBridgeReadCB: Frame size 207
Sun Dec 15 20:54:52 2024 daemon.info gwBridge[1918]: Enter gwBridgeFrameRcv, mdCreateEvent 0 Frame Len 207
Sun Dec 15 20:54:52 2024 daemon.info gwBridge[1918]: Uplink Packet from Gateway ac1f09fffe015f5e
Sun Dec 15 20:54:52 2024 daemon.info gwBridge[1918]: Uplink - {“rxpk”:[{“tmst”:1858284340,“chan”:4,“rfch”:0,“freq”:486.300000,“stat”:1,“modu”:“LORA”,“datr”:“SF9BW125”,“codr”:“4/5”,“lsnr”:11.5,“rssi”:-80,“size”:23,“data”:“QNslASYA8FEDfDU5L9BtbWFEo/cjido=”}]}
Sun Dec 15 20:54:52 2024 user.info lora_pkt_fwd[2084]: INFO: [up] PUSH_ACK received in 4 ms
Sun Dec 15 20:54:52 2024 daemon.info nwkSrv[1918]: Enter nsEventUplinkRcvCB, gwforward data len: 360, payload len: 23
Sun Dec 15 20:54:52 2024 daemon.info nwkSrv[1918]: Receive uplink message type 2
Sun Dec 15 20:54:52 2024 daemon.info lorawan[1918]: mote 4f0f6d8fafcebb33 260125db frame-count uplink - 20976
Sun Dec 15 20:54:52 2024 daemon.err nwkSrv[1918]: __nsParseDataFrame: data mic check failed
Sun Dec 15 20:54:54 2024 user.debug wisdm[24359]: cert root directory rakwireless
Sun Dec 15 20:54:54 2024 user.info wisdm[24359]: AWS IoT SDK Version 3.0.1-
Sun Dec 15 20:54:54 2024 user.info wisdm[24359]: WisDM Agent Version 1.0.1
Sun Dec 15 20:54:54 2024 user.info wisdm[24359]: ThingName 9181000R1A900782
Sun Dec 15 20:54:55 2024 user.err wisdm[24359]: device aes read ERROR
接收正常的包
Sun Dec 15 21:05:53 2024 user.err wisdm[32068]: Shadow Connection Error
Sun Dec 15 21:05:55 2024 user.debug lora_pkt_fwd[2084]: rrd_statistic_up 367 uplinkTqByAirtime : dr = 4, timeonair = 102, tm = 1734267955
Sun Dec 15 21:05:55 2024 user.debug lora_pkt_fwd[2084]: rrd_statistic_up 369 uplinkTqByPkt : dr = 4, tm = 1734267955
Sun Dec 15 21:05:55 2024 user.debug lora_pkt_fwd[2084]: rrd_statistic_up 371 ChanBusyByAirtime chan 5, timeonair = 102, tm = 1734267955
Sun Dec 15 21:05:55 2024 user.debug lora_pkt_fwd[2084]: Uplink Frame :
Sun Dec 15 21:05:55 2024 user.debug lora_pkt_fwd[2084]: 40 DB 25 01 26 00 3C C7
Sun Dec 15 21:05:55 2024 user.debug lora_pkt_fwd[2084]: 03 4E 26 5E 5D 4A 03 03
Sun Dec 15 21:05:55 2024 user.debug lora_pkt_fwd[2084]: C2 C2 EF 3B AD 36 6A
Sun Dec 15 21:05:55 2024 user.info lora_pkt_fwd[2084]: JSON up: {“rxpk”:[{“tmst”:2521087844,“chan”:5,“rfch”:0,“freq”:486.500000,“stat”:1,“modu”:“LORA”,“datr”:“SF8BW125”,“codr”:“4/5”,“lsnr”:9.8,“rssi”:-82,“size”:23,“data”:“QNslASYAPMcDTiZeXUoDA8LC7zutNmo=”}]}
Sun Dec 15 21:05:55 2024 daemon.info gwBridge[1918]: gwBridgeReadCB: Frame size 206
Sun Dec 15 21:05:55 2024 daemon.info gwBridge[1918]: Enter gwBridgeFrameRcv, mdCreateEvent 0 Frame Len 206
Sun Dec 15 21:05:55 2024 daemon.info gwBridge[1918]: Uplink Packet from Gateway ac1f09fffe015f5e
Sun Dec 15 21:05:55 2024 daemon.info gwBridge[1918]: Uplink - {“rxpk”:[{“tmst”:2521087844,“chan”:5,“rfch”:0,“freq”:486.500000,“stat”:1,“modu”:“LORA”,“datr”:“SF8BW125”,“codr”:“4/5”,“lsnr”:9.8,“rssi”:-82,“size”:23,“data”:“QNslASYAPMcDTiZeXUoDA8LC7zutNmo=”}]}
Sun Dec 15 21:05:55 2024 user.info lora_pkt_fwd[2084]: INFO: [up] PUSH_ACK received in 5 ms
Sun Dec 15 21:05:55 2024 daemon.info nwkSrv[1918]: Enter nsEventUplinkRcvCB, gwforward data len: 360, payload len: 23
Sun Dec 15 21:05:55 2024 daemon.info nwkSrv[1918]: Receive uplink message type 2
Sun Dec 15 21:05:55 2024 daemon.info lorawan[1918]: mote 4f0f6d8fafcebb33 260125db frame-count uplink - 51004
Sun Dec 15 21:05:55 2024 daemon.info nwkSrv[1918]: nsDeduplicateFrameTimerHandler: Mote Devaddr: 0x260125db FCnt: 51004 Best signal quality: 35
Sun Dec 15 21:05:55 2024 daemon.info nwkSrv[1918]: nsForwardAppPayload: Forwarding application payload to appSrv payload_len: 10
Sun Dec 15 21:05:55 2024 daemon.info appSrv[1918]: Enter appEventNsUplinkRcvCB, DevAddr:0x260125db, FRMPayload len: 10
Sun Dec 15 21:05:55 2024 daemon.info appSrv[1918]: [Uplink] - {“applicationID”:“2”,“applicationName”:“rakdevice”,“devEUI”:“4f0f6d8fafcebb33”,“deviceName”:“rak_dev1”,“timestamp”:1734267955,“fCnt”:51004,“fPort”:3,“data”:“AgAAAABuK2NAAw==”,“data_encode”:“base64”,“adr”:false,“rxInfo”:[{“gatewayID”:“ac1f09fffe015f5e”,“loRaSNR”:9.8,“rssi”:-82,“location”:{“latitude”:0.000000,“longitude”:0.000000,“altitude”:0}}],“txInfo”:{“frequency”:486500000,“dr”:4}}
Sun Dec 15 21:05:55 2024 daemon.info mqttEv[1918]: mqttEvPublish : [[AppSrv Mqtt Client]] publish - [386][{“applicationID”:“2”,“applicationName”:“rakdevice”,“devEUI”:“4f0f6d8fafcebb33”,“deviceName”:“rak_dev1”,“timestamp”:1734267955,“fCnt”:51004,“fPort”:3,“data”:“AgAAAABuK2NAAw==”,“data_encode”:“base64”,“adr”:false,“rxInfo”:[{“gatewayID”:“ac1f09fffe015f5e”,“loRaSNR”:9.8,“rssi”:-82,“location”:{“latitude”:0.000000,“longitude”:0.000000,“altitude”:0}}],“txInfo”:{“frequency”:486500000,“dr”:4}}]
Sun Dec 15 21:05:55 2024 daemon.info mqttEv[1918]: mqttEvPublish : [[AppSrv Local Mqtt Client]] publish - [386][{“applicationID”:“2”,“applicationName”:“rakdevice”,“devEUI”:“4f0f6d8fafcebb33”,“deviceName”:“rak_dev1”,“timestamp”:1734267955,“fCnt”:51004,“fPort”:3,“data”:“AgAAAABuK2NAAw==”,“data_encode”:“base64”,“adr”:false,“rxInfo”:[{“gatewayID”:“ac1f09fffe015f5e”,“loRaSNR”:9.8,“rssi”:-82,“location”:{“latitude”:0.000000,“longitude”:0.000000,“altitude”:0}}],“txInfo”:{“frequency”:486500000,“dr”:4}}]
