Occurrence of data outliers between sensor numerical tests depending on frequency
Hello, I purchased the ra3172 kr920, and an outlier occurred between the sensor numerical tests according to the frequency for CE certification. I am curious about how to resolve it.
Outliers occurred around 45MHz, 95MHz, and 1000MHz.
The sensor frequency was set as follows.
AT+P2P=919000000:12:125:3:85:22
I understand that the frequency range according to the existing specifications is from 150MHz to 960MHz, but I would appreciate it if you could tell me if there is a way to catch the outlier.
thank you
Welcome to the forum @jhsong
Can you explain what you mean with
I am not sure if I understand.
I don’t understand as well why you check for CE certification on a device that is setup for Korea. The used frequency ranges are different.
