Issue: I am configuring the connection through OTAA of a RAK815 device, towards a Kerlink Gateway with internal LNS, which the Join Accept fails several times since apparently I have not configured the masks correctly. When it manages to receive the Join Accept, the program works as expected but when you restart it, it fails again. I have configured the RAK7200 and RAK7205 correctly towards the same gateway, but it worked only after I correctly assigned the channels with the command at + set_config = lora: ch_mask: X: Y
Setup: program with KEIL, using Peripherals DEMO and Lorawan DEMO, burn with j-link, frequency AU915.
Server: Kerlink SPN
Details: Could someone help me to correctly configure the given example code? For now I am trying to modify the RegionAU915.h file but without results.
Thanks everybody!
