Hello RAKwireless Community,
We are planning to use the RAK7268CV2 (EU868) gateway .
Our goal is to keep the gateway indoors while mounting an external LoRaWAN antenna outdoors to improve coverage.
We would appreciate some technical recommendations regarding the following:
- Which outdoor omnidirectional antenna would you recommend for the RAK7268CV2 (EU868)?
- Does RAKwireless offer a compatible low-loss coaxial cable of approximately 5–10 metres?
- Can you confirm the exact RF connector type on the gateway’s LoRa antenna port and the required connector on the coaxial cable?
- Are there any recommended antenna mounting accessories or lightning protection devices?
- Could you share product links for a complete compatible antenna and cable setup?
We want to ensure proper RF connector compatibility and minimize signal loss.
Thank you in advance for your support!
