1: Is it possible to override the factory settings and keep them persistent? Example: I want to activate the WisDM option and after I press the reset button on the device, the setting should be stil enabled.
“reset” is unfortunately a word with multiple meanings
The software system on this box descends from that of wifi routers, where the role of the “reset” button is not really to do a hardware reset (reboot), but rather to reset configuration to factory defaults.
According to the manual, a short press apparently does do a simple hardware reset, but a long press resets configuration.
Personally, I’d use the button only for configuration reset, and if I wanted to a reboot I’d power cycle it instead.
thanks for your response.
OK with reset I mean. reset configuration to factory defaults
so I meant to override the factory defaults and keep them persistent.
Example: The LoRa-Gateway is placed in a class room at school. One student is quite funny and presses the Reset Button for a long time and resets configuration to factory defaults
To change the factory defaults you’d have to use squashfs tools to unpack and repack a system upgrade image, possibly after splitting it from and recombining with the kernal.
You do better to epoxy a cover over the reset button hole and physically open the unit if you ever need it.
Or walk it down to the metal shop and have someone make a strap that encircles the case covering the hole and secures it against theft.
Or put the gateway in a locked room, you don’t want it too close to nodes anyway.
There might(?) be a backup offline and restore function though?
One other example: For some reason the gateway is not working anymore and a reboot does not help. So the only solution is to reset the gateway (not far ago I had such case).
If the gateway is at the customers place (wherever it is i.e 400km far away from my place) the only thing I would need to tell my customer is to press the reset button for 10 secs. All further configuration I would then could do via WisDM. But as I cannot override factory settings WisDM is disabled by default.
If you wish to unpack the squashfs, modify it, then re-pack and re-flash it, that’s up to you
Worth noting that a mixup in that process is likely to result in a gateway that can’t boot at all, so you’ll want to review the procedure for recovery with a serial cable and TFTP server.
