Dears,
I setup RAKwireless on raspberry pi 3B
PRETTY_NAME=“Raspbian GNU/Linux 10 (buster)”
NAME=“Raspbian GNU/Linux”
VERSION_ID=“10”
VERSION=“10 (buster)”
VERSION_CODENAME=buster
ID=raspbian
ID_LIKE=debian
rak config files were configured with proper application EUIS…
but I am still running the pi on wireless network. Is it a problem ? does it work excusively on Eth copper connection ?
Another question is how to setup any node > I just got those 2 heltech wireless stick lite (Lora WiFi BLE & Li-Po management)…
what code shall I runn to get the first uplink to TTN network ?
Regards,
ps: I would appreciate if I could contact in private a dev. to verify the config…
The Pi Supply IoT LoRa Gateway HAT allows you to create an inexpensive LoRa gateway, compatible with The Things Network, in conjunction with a Raspberry Pi or other single board computers. The HAT allows you to set up your IoT LoRa gateway in minutes...
Price: GBP 108.32
Nikola
(Nikola Semov)
October 2, 2020, 10:59am
2
Hi @dpasquazzo ,
Have you registered your gateway in your TTN console? Is the gateway’s status connected?
As for the network connection, it doesn’t matter if you use an Eth connection or wireless network. Your gateway EUI would be created based on the interface that you use to connect the network.
Nikola
(Nikola Semov)
October 2, 2020, 11:11am
4
@dpasquazzo
Do you mean the gateway named “alf”?
Which software for rak2247 do you use? From RAK or from PI Supply?
this is the gateway i just have inserted istead of all 0 in the file below: eui-b827eb8db1f6fffe
pi@rak-gateway:/opt/ttn-gateway/packet_forwarder/lora_pkt_fwd $ pi@rak-gateway:/opt/ttn-gateway/packet_forwarder/lora_pkt_fwd $ sudo vi global_conf.json
I use raspian with the git-hub of rak.
files edidted in opt/ttn-gateway folder as above…
maybe it will connect now ?
Nikola
(Nikola Semov)
October 2, 2020, 11:23am
6
@dpasquazzo
As you use Pi Supply hardware the pin mapping is not the same as RAK’s hardware.
For more information, you can refer to this guide https://learn.pi-supply.com/make/iot-lora-gateway-sd-card-image-setup/
Appreciated @Nikola
So I am stuck with balena.io that I don’t like much and couldn’t get it works neither .-)
Nikola
(Nikola Semov)
October 2, 2020, 11:49am
8
system
(system)
Closed
October 4, 2020, 11:49am
9
