Hey There,
I am having trouble getting the ping watchdog to work properly with the RAK7258 Ethernet/Cellular.
I would like to have the gateway primarily on ethernet, but in the case of the ethernet connection going down, switch to cellular, then back again if ethernet is re-established.
I set up the ping watchdog for both the ethernet (wan) and cellular (wwan) interfaces, and set the priorities accordingly. I have tried various priorities that follow the priority rule (lowest number is highest priority) to try and get it working but with all of this set up, I am having no luck.
It seems to be connected when the ethernet and sim card are plugged into the gateway but when I try to test by removing the ethernet connection, it will not switch to cellular.
Any help would be appreciated!
Thanks.
