What product do you wish to discuss? RAK4631-R
What firmware are you using? (RUI3 or Arduino BSP or other IDE (e.g. STM32CubeIDE)? RUI3
What firmware version? Can it be obtained with AT+VER=?
Computer OS? (MacOS, Linux, Windows)
What Computer OS version?
How often does the problem happen?
How can we replicate the problem?
Provide source code if custom firmware is used or link to example if RAKwireless example code is used: WisBlock/examples/RAK4630/solutions/Hydraulic_Pressure_Monitoring at master · RAKWireless/WisBlock · GitHub
What Computer OS version? Windows 11
How often does the problem happen? Always
How can we replicate the problem? Yes
Good afternoon,
After I did the RAK4631 to RAK4631-R by WisToolBox, in the same code compiling/build process in the VSCode/PlatformIO, it seems that the serial port is not available in the build process following the error messages below:
Could you help to understand why in Arduino BSP mode is working and with RUI3 is not working?
Regards,
Cláudio
Blockquote
Executing task: C:\Users\Claudio Rosa.platformio\penv\Scripts\platformio.exe run --target upload
Processing wiscore_rak4631 (platform: nordicnrf52; board: wiscore_rak4631; framework: arduino)
Verbose mode can be enabled via -v, --verbose option
CONFIGURATION: https://docs.platformio.org/page/boards/nordicnrf52/wiscore_rak4631.html
PLATFORM: Nordic nRF52 (10.3.0) > WisCore RAK4631 Board
HARDWARE: NRF52840 64MHz, 243KB RAM, 796KB Flash
DEBUG: Current (jlink) External (jlink, stlink)
PACKAGES:
- framework-arduinoadafruitnrf52 @ 1.10600.0 (1.6.0)
- framework-cmsis @ 2.50700.210515 (5.7.0)
- tool-adafruit-nrfutil @ 1.503.0 (5.3)
- tool-bossac-nordicnrf52 @ 1.10901.201022 (1.9.1)
- tool-openocd @ 3.1200.0 (12.0)
- tool-sreccat @ 1.164.0 (1.64)
- toolchain-gccarmnoneeabi @ 1.70201.0 (7.2.1)
LDF: Library Dependency Finder → Library Dependency Finder (LDF) — PlatformIO latest documentation
LDF Modes: Finder ~ chain, Compatibility ~ soft
Found 15 compatible libraries
Scanning dependencies…
Dependency Graph
|-- SX126x-Arduino @ 2.0.23
|-- SPI @ 1.0
Building in release mode
Checking size .pio\build\wiscore_rak4631\firmware.elf
Advanced Memory Usage is available via “PlatformIO Home > Project Inspect”
RAM: [= ] 6.0% (used 15016 bytes from 248832 bytes)
Flash: [== ] 15.8% (used 128584 bytes from 815104 bytes)
Configuring upload protocol…
AVAILABLE: jlink, nrfjprog, nrfutil, stlink
CURRENT: upload_protocol = nrfutil
Looking for upload port…
Auto-detected: COM9
Forcing reset using 1200bps open/close on port COM9
Waiting for the new upload port…
Uploading .pio\build\wiscore_rak4631\firmware.zip
Upgrading target on COM9 with DFU package F:\Users\Claudio Rosa\OneDrive - Nas Ondas Projetos de Inovação\Clientes\MRS\Projetos\Endnodes\Pressão 4-20\Horto.pio\build\wiscore_rak4631\firmware.zip. Flow control is disabled, Single bank, Touch disabled
Failed to upgrade target. Error is: No data received on serial port. Not able to proceed.
Timed out waiting for acknowledgement from device.
File “C:\Users\Claudio Rosa.platformio\packages\tool-adafruit-nrfutil\site-packages\nordicsemi_main_.py”, line 296, in serial
dfu.dfu_send_images()
File “C:\Users\Claudio Rosa.platformio\packages\tool-adafruit-nrfutil\site-packages\nordicsemi\dfu\dfu.py”, line 235, in dfu_send_images
self._dfu_send_image(HexType.APPLICATION, self.manifest.application)
File “C:\Users\Claudio Rosa.platformio\packages\tool-adafruit-nrfutil\site-packages\nordicsemi\dfu\dfu.py”, line 199, in _dfu_send_image
self.dfu_transport.send_start_dfu(program_mode, softdevice_size, bootloader_size,
File “C:\Users\Claudio Rosa.platformio\packages\tool-adafruit-nrfutil\site-packages\nordicsemi\dfu\dfu_transport_serial.py”, line 179, in send_start_dfu
self.send_packet(packet)
File “C:\Users\Claudio Rosa.platformio\packages\tool-adafruit-nrfutil\site-packages\nordicsemi\dfu\dfu_transport_serial.py”, line 243, in send_packet
ack = self.get_ack_nr()
File “C:\Users\Claudio Rosa.platformio\packages\tool-adafruit-nrfutil\site-packages\nordicsemi\dfu\dfu_transport_serial.py”, line 282, in get_ack_nr
raise NordicSemiException(“No data received on serial port. Not able to proceed.”)
nordicsemi.exceptions.NordicSemiException: No data received on serial port. Not able to proceed.
Possible causes:
- Selected Bootloader version does not match the one on Bluefruit device.
Please upgrade the Bootloader or select correct version in Tools->Bootloader. - Baud rate must be 115200, Flow control must be off.
- Target is not in DFU mode. Ground DFU pin and RESET and release both to enter DFU mode.
==================================================== [SUCCESS] Took 16.37 seconds ====================================================
- Terminal will be reused by tasks, press any key to close it.
Blockquote
