System Setup:
RAK19007+RAK 3400+RAK13302 (newer battery-only version - code RAK13302 VD)
Power: Battery connection - 4 battery module (parallel) - NCR18650, 3300mAh; Solar connection - Instead of a solar panel I am using an Anker USB charger 5V/3A connected to a 120VAC outlet.
Issue: This module is identified as the “battery-only” version so it does not have the 3-pin jumper on the 13302 board to select 5V external input. I have the battery pack connected to the Battery connector on the 19007 and I have the USB power source connected to the Solar connector on the 19007. The system has been working fine but after about 3 weeks of use, the battery pack is now down below 10%. I was under the impression that the 5V input from the Solar connector was used to charge the batteries as well as provide additional power to achieve 1w. Is this not correct, or is there some other specification the Solar input must meet to handle the load of recharging the batteries?
