Hello ! I have a problem with rak v2! I installed it a month ago and it fails to do witnes. Good location, neighbors are nearby, what’s the matter?
Hey,
Oddly enough despite the status I am unable to reach it, could you diagnose it?
Or better yet pop to out discord and open a ticket for some real time support.
Vladislav
Hello ! can you try now maybe you can find it … thank you very much! it doesn’t produce anything for 2 months … it doesn’t make witnes
Hey @Madalinmdl ,
I just checked on it and it would seem its connection is not stable, has been re-activated by a validator many times over the past week or so. You really should diagnose it, it will tell us more about any potential issues.
Vladislav
Ok this one is good, as far a connectivity at the time. This is how it should work for a properly connected one at the time, you have also been market activated recently. Let it work as it is over the day, it should start activity.
Vladislav
81 / 5.000
but still I don’t understand why he doesn’t witness, and he hasn’t had any activity for 2 months.
can you help me with an answer? or I can forget about this miner … money thrown out the window
I had recent activity actually, seems you changed the location after.
Probably why you have not had a beacon yet, from what I can see you are removed from nearby hotspots and your beacons are not seen.
I am guessing you don’t have an outdoor deployment, correct?
I recently changed my location to be alone in the hex. I have a 5.8 external antenna and a 10 meter wire. do not witness! could it be a software problem?
