@ZhuQI,
Thanks for your quick response I did the steps and here is the log
Version: 4.0.1
Version: 5.0.1;
INFO: Little endian host
INFO: antenna_gain 0 dBi
INFO: Configuring TX LUT with 16 indexes
INFO: radio 0 enabled (type SX1257), center frequency 904300000, RSSI offset -166.000000, tx enabled 1, tx_notch_freq 0
INFO: radio 1 enabled (type SX1257), center frequency 905000000, RSSI offset -166.000000, tx enabled 0, tx_notch_freq 0
INFO: Lora multi-SF channel 0> radio 0, IF -400000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 1> radio 0, IF -200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 2> radio 0, IF 0 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 3> radio 0, IF 200000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 4> radio 1, IF -300000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 5> radio 1, IF -100000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 6> radio 1, IF 100000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora multi-SF channel 7> radio 1, IF 300000 Hz, 125 kHz bw, SF 7 to 12
INFO: Lora std channel> radio 0, IF 300000 Hz, 500000 Hz bw, SF 8
INFO: FSK channel 8 disabled
INFO: global_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
INFO: gateway MAC address is configured to 0000000000000000
INFO: server hostname or IP address is configured to “router.us.thethings.network”
INFO: upstream port is configured to “1700”
INFO: downstream port is configured to “1700”
INFO: downstream keep-alive interval is configured to 10 seconds
INFO: statistics display interval is configured to 30 seconds
INFO: upstream PUSH_DATA time-out is configured to 100 ms
INFO: GPS serial port path is configured to “/dev/ttyAMA0”
INFO: Reference latitude is configured to 10.000000 deg
INFO: Reference longitude is configured to 20.000000 deg
INFO: Reference altitude is configured to -1 meters
INFO: fake GPS is disabled
INFO: Auto-quit after 20 non-acknowledged PULL_DATA
INFO: found local configuration file local_conf.json, parsing it
INFO: redefined parameters will overwrite global parameters
INFO: local_conf.json does not contain a JSON object named SX1301_conf
INFO: local_conf.json does contain a JSON object named gateway_conf, parsing gateway parameters
INFO: gateway MAC address is configured to B827EBFFFEB0043F
INFO: [main] TTY port /dev/ttyAMA0 open for GPS synchronization
INFO: [main] concentrator started, packet can now be received
INFO: Disabling GPS mode for concentrator’s counter…
INFO: host/sx1301 time offset=(1583725518s:916708µs) - drift=-721810332µs
INFO: Enabling GPS mode for concentrator’s counter.
WARNING: [gps] GPS out of sync, keeping previous time reference
INFO: [down] PULL_ACK received in 159 ms
INFO: Received pkt from mote: D002C00C (fcnt=46037)
JSON up: {“rxpk”:[{“tmst”:8941700,“time”:“2020-03-09T03:45:34.269414Z”,“tmms”:1267760751269,“chan”:2,“rfch”:0,“freq”:904.300000,“stat”:1,“modu”:“LORA”,“datr”:“SF10BW125”,“codr”:“4/5”,“lsnr”:7.5,“rssi”:-7,“size”:23,“data”:“AAzAAtB+1bNwcRZ4/v+oxWB99tqAlrc=”}]}
INFO: [down] PULL_ACK received in 158 ms
INFO: [down] PULL_RESP received - token[0:10]
JSON down: {“txpk”:{“imme”:false,“tmst”:13941700,“freq”:924.5,“rfch”:0,“powe”:17,“modu”:“LORA”,“datr”:“SF10BW500”,“codr”:“4/5”,“ipol”:true,“size”:17,“ncrc”:true,“data”:“IJyqJkAML40RJKzD2otpPZg=”}}
ERROR: Packet REJECTED, unsupported RF power for TX - 17
JSON up: {“rxpk”:[{“tmst”:16007988,“time”:“2020-03-09T03:45:48.335701Z”,“tmms”:1267760765335,“chan”:3,“rfch”:0,“freq”:904.500000,“stat”:1,“modu”:“LORA”,“datr”:“SF10BW125”,“codr”:“4/5”,“lsnr”:-15.0,“rssi”:-77,“size”:23,“data”:“AAzAAtB+1bNwcRZ4/v+oxWC7uw66hJQ=”},{“tmst”:16007988,“time”:“2020-03-09T03:45:48.335701Z”,“tmms”:1267760765335,“chan”:6,“rfch”:1,“freq”:905.100000,“stat”:1,“modu”:“LORA”,“datr”:“SF10BW125”,“codr”:“4/5”,“lsnr”:12.0,“rssi”:-10,“size”:23,“data”:“AAzAAtB+1bNwcRZ4/v+oxWC7uw66hJQ=”}]}
INFO: [down] PULL_RESP received - token[0:11]
JSON down: {“txpk”:{“imme”:false,“tmst”:21007988,“freq”:925.1,“rfch”:0,“powe”:17,“modu”:“LORA”,“datr”:“SF10BW500”,“codr”:“4/5”,“ipol”:true,“size”:17,“ncrc”:true,“data”:“IEtAlrdGgtdhbY719cvRn6g=”}}
INFO: [down] PULL_ACK received in 161 ms
JSON up: {“rxpk”:[{“tmst”:23073540,“time”:“2020-03-09T03:46:02.401254Z”,“tmms”:1267760779401,“chan”:7,“rfch”:1,“freq”:905.300000,“stat”:1,“modu”:“LORA”,“datr”:“SF10BW125”,“codr”:“4/5”,“lsnr”:11.5,“rssi”:-11,“size”:23,“data”:“AAzAAtB+1bNwcRZ4/v+oxWAgeGvTRq4=”}]}
INFO: [down] PULL_RESP received - token[0:12]
JSON down: {“txpk”:{“imme”:false,“tmst”:28073540,“freq”:927.5,“rfch”:0,“powe”:17,“modu”:“LORA”,“datr”:“SF10BW500”,“codr”:“4/5”,“ipol”:true,“size”:17,“ncrc”:true,“data”:“IJDw3KRaF0sqENNXAm0fIS4=”}}
JSON up: {“rxpk”:[{“tmst”:30140460,“time”:“2020-03-09T03:46:17.468174Z”,“tmms”:1267760794468,“chan”:4,“rfch”:1,“freq”:904.700000,“stat”:1,“modu”:“LORA”,“datr”:“SF10BW125”,“codr”:“4/5”,“lsnr”:11.8,“rssi”:-9,“size”:23,“data”:“AAzAAtB+1bNwcRZ4/v+oxWCcZUQtIP8=”}]}
2020-03-09 03:45:51 GMT
[UPSTREAM]
RF packets received by concentrator: 5
CRC_OK: 100.00%, CRC_FAIL: 0.00%, NO_CRC: 0.00%
RF packets forwarded: 5 (115 bytes)
PUSH_DATA datagrams sent: 4 (1295 bytes)
PUSH_DATA acknowledged: 0.00%
[DOWNSTREAM]
PULL_DATA sent: 3 (100.00% acknowledged)
PULL_RESP(onse) datagrams received: 3 (567 bytes)
RF packets sent to concentrator: 0 (51 bytes)
TX errors: 0
BEACON queued: 0
BEACON sent so far: 0
BEACON rejected: 0
[JIT]
SX1301 time (PPS): 2672286
src/jitqueue.c:448:jit_print_queue(): INFO: [jit] queue is empty
[GPS]
Valid time reference (age: 0 sec)
no valid GPS coordinates available yet
END
JSON up: {“stat”:{“time”:“2020-03-09 03:45:51 GMT”,“rxnb”:5,“rxok”:5,“rxfw”:5,“ackr”:0.0,“dwnb”:3,“txnb”:0}}
INFO: [down] PULL_RESP received - token[0:13]
JSON down: {“txpk”:{“imme”:false,“tmst”:35140460,“freq”:925.7,“rfch”:0,“powe”:17,“modu”:“LORA”,“datr”:“SF10BW500”,“codr”:“4/5”,“ipol”:true,“size”:17,“ncrc”:true,“data”:“IM26qoY/hOHWM+yUl3gn/lM=”}}
