Hi, I have made a number of rain gauges using the 19007 and RAK4631. All the device is doing is counting interrupts and uploading every 10 minutes. For some unknown reason, some of these devices (not all) run out of battery after a period of time (not consistent). I’m trying to figure out what could be happening. The power consumption is usually tiny, I don’t lose more than 0.1v, even after overcast weather, and the ones that are working have been working well for over a year. I’m assuming they get caught in some sort of loop and can’t go to sleep, as the voltage drops from full to dead over a couple of days.
I’ll add the code. I’m wondering if there’s some sort of safeguard I can add, or whether there’s something in the code that could be improved to help. It’s a pretty simple sketch, the vast majority is the Deepsleep/lorawan sketch with the counter and battery voltage added.
Any help would be greatly appreciated…
#include <Arduino.h>
#include <SPI.h>
#include <LoRaWan-RAK4630.h>
uint32_t SLEEP_TIME = 600000;
int current_sensor_payload;
//Battery Voltage************************************************************************
#define PIN_VBAT WB_A0
uint32_t vbat_pin = PIN_VBAT;
#define VBAT_MV_PER_LSB (0.73242188F) // 3.0V ADC range and 12 - bit ADC resolution = 3000mV / 4096
#define VBAT_DIVIDER_COMP (1.73) // Compensation factor for the VBAT divider, depend on the board
#define REAL_VBAT_MV_PER_LSB (VBAT_DIVIDER_COMP * VBAT_MV_PER_LSB)
// Comment the next line if you want DEBUG output. But the power savings are not as good then!!!!!!!
//#define MAX_SAVE
/* Time the device is sleeping in milliseconds = 2 minutes * 60 seconds * 1000 milliseconds */
extern uint32_t SLEEP_TIME;
// LoRaWan stuff
int8_t initLoRaWan(void);
bool sendLoRaFrame(void);
extern SemaphoreHandle_t loraEvent;
// Main loop stuff
void periodicWakeup(TimerHandle_t unused);
extern SemaphoreHandle_t taskEvent;
extern uint8_t rcvdLoRaData[];
extern uint8_t rcvdDataLen;
extern uint8_t eventType;
extern SoftwareTimer taskWakeupTimer;
//Rain Global****************************************************************************
#define rainPin WB_IO1 //Red wire to WB_I01, Green to ground
int rain = 0;
/** Semaphore used by events to wake up loop task */
SemaphoreHandle_t taskEvent = NULL;
/** Timer to wakeup task frequently and send message */
/** Buffer for received LoRaWan data */
uint8_t rcvdLoRaData[256];
/** Length of received data */
uint8_t rcvdDataLen = 0;
uint8_t eventType = -1;
* @brief Timer event that wakes up the loop task frequently
* @param unused
// Switch off blue LED to save power during sleep
digitalWrite(LED_CONN, LOW);
eventType = 1;
// Give the semaphore, so the loop task will wake up
xSemaphoreGiveFromISR(taskEvent, pdFALSE);
/** DIO1 GPIO pin for RAK4631 */
#define PIN_LORA_DIO_1 47
/** Max size of the data to be transmitted. */
#define LORAWAN_APP_DATA_BUFF_SIZE 64
/** Number of trials for the join request. */
#define JOINREQ_NBTRIALS 8
/** Lora application data buffer. */
static uint8_t m_lora_app_data_buffer[LORAWAN_APP_DATA_BUFF_SIZE];
/** Lora application data structure. */
static lmh_app_data_t m_lora_app_data = {m_lora_app_data_buffer, 0, 0, 0, 0};
// LoRaWan event handlers
/** LoRaWan callback when join network finished */
/** LoRaWan callback when join failed */
/** LoRaWan callback when data arrived */
/** LoRaWan callback after class change request finished */
/** LoRaWan Function to send a package */
* Set structure members to
* LORAWAN_ADR_ON or LORAWAN_ADR_OFF to enable or disable adaptive data rate
* LORAWAN_DEFAULT_DATARATE OR DR_0 ... DR_5 for default data rate or specific data rate selection
* LORAWAN_PUBLIC_NETWORK or LORAWAN_PRIVATE_NETWORK to select the use of a public or private network
* JOINREQ_NBTRIALS or a specific number to set the number of trials to join the network
* LORAWAN_DEFAULT_TX_POWER or a specific number to set the TX power used
* LORAWAN_DUTYCYCLE_ON or LORAWAN_DUTYCYCLE_OFF to enable or disable duty cycles
* Please note that ETSI mandates duty cycled transmissions.
static lmh_param_t lora_param_init = {LORAWAN_ADR_ON, DR_0, LORAWAN_PUBLIC_NETWORK, JOINREQ_NBTRIALS, LORAWAN_DEFAULT_TX_POWER, LORAWAN_DUTYCYCLE_OFF};
/** Structure containing LoRaWan callback functions, needed for lmh_init() */
static lmh_callback_t lora_callbacks = {BoardGetBatteryLevel, BoardGetUniqueId, BoardGetRandomSeed,
lorawan_rx_handler, lorawan_has_joined_handler, lorawan_confirm_class_handler, lorawan_join_failed_handler};
// !!!! KEYS ARE MSB !!!!
/** Device EUI required for OTAA network join */
uint8_t nodeDeviceEUI[8] = {};
uint8_t nodeAppEUI[8] = {};
uint8_t nodeAppKey[16] = {};
/** Device address required for ABP network join */
uint32_t nodeDevAddr = ;
uint8_t nodeNwsKey[16] = {};
uint8_t nodeAppsKey[16] = {};
/** Flag whether to use OTAA or ABP network join method */
bool doOTAA = true;
DeviceClass_t gCurrentClass = CLASS_A; /* class definition*/
LoRaMacRegion_t gCurrentRegion = LORAMAC_REGION_AU915; /* Region:EU868*/
Serial.printf("<<>> lora_rak4630_init called at %dms\n", millis());
// Initialize LoRa chip.
if (lora_rak4630_init() != 0)
return -1;
Serial.printf("<<>> lora_rak4630_init finished at %dms\n", millis());
delay(100);
// Setup the EUIs and Keys
if (doOTAA)
lmh_setDevEui(nodeDeviceEUI);
lmh_setAppEui(nodeAppEUI);
lmh_setAppKey(nodeAppKey);
else
lmh_setNwkSKey(nodeNwsKey);
lmh_setAppSKey(nodeAppsKey);
lmh_setDevAddr(nodeDevAddr);
Serial.printf("<<>> lmh_init called at %dms\n", millis());
// Initialize LoRaWan
if (lmh_init(&lora_callbacks, lora_param_init, doOTAA, gCurrentClass, gCurrentRegion) != 0)
return -2;
Serial.printf("<<>> lmh_init finished at %dms\n", millis());
delay(100);
// For some regions we might need to define the sub band the gateway is listening to
// This must be called AFTER lmh_init()
if (!lmh_setSubBandChannels(2))
return -3;
// Start Join procedure
#ifndef MAX_SAVE
Serial.printf("<<>> lmh_join called at %dms\n", millis());
#endif
lmh_join();
Serial.printf("<<>> lmh_join finished at %dms\n", millis());
delay(100);
return 0;
Serial.printf("<<>> lorawan_has_joined_handler called at %dms\n", millis());
delay(100);
if (doOTAA)
uint32_t otaaDevAddr = lmh_getDevAddr();
#ifndef MAX_SAVE
Serial.printf("OTAA joined and got dev address %08X\n", otaaDevAddr);
#endif
else
#ifndef MAX_SAVE
Serial.println("ABP joined");
#endif
// Default is Class A, where the SX1262 transceiver is in sleep mode unless a package is sent
// If switched to Class C the power consumption is higher because the SX1262 chip remains in RX mode
// lmh_class_request(CLASS_C);
// Now we are connected, start the timer that will wakeup the loop frequently
taskWakeupTimer.begin(SLEEP_TIME, periodicWakeup);
taskWakeupTimer.start();
eventType = 1;
// Notify task about the event
if (taskEvent != NULL)
Serial.printf("<<>> Waking up task at %dms\n", millis());
xSemaphoreGive(taskEvent);
Serial.println("OVER_THE_AIR_ACTIVATION failed!");
* @brief Function for handling LoRaWan received data from Gateway
* @param app_data Pointer to rx data
#ifndef MAX_SAVE
Serial.printf("LoRa Packet received on port %d, size:%d, rssi:%d, snr:%d\n",
app_data->port, app_data->buffsize, app_data->rssi, app_data->snr);
#endif
switch (app_data->port)
case 3:
// Port 3 switches the class
if (app_data->buffsize == 1)
switch (app_data->buffer[0])
case 0:
lmh_class_request(CLASS_A);
#ifndef MAX_SAVE
Serial.println("Request to switch to class A");
#endif
break;
case 1:
lmh_class_request(CLASS_B);
#ifndef MAX_SAVE
Serial.println("Request to switch to class B");
#endif
break;
case 2:
#ifndef MAX_SAVE
Serial.println("Request to switch to class C");
#endif
break;
default:
break;
break;
case LORAWAN_APP_PORT:
// Copy the data into loop data buffer
memcpy(rcvdLoRaData, app_data->buffer, app_data->buffsize);
rcvdDataLen = app_data->buffsize;
eventType = 0;
// Assuming the new time is encoded as 3 bytes. e.g. 30=> 0x00, 0x00, 0x1F
// Downlink must be sent on Port2
// Downlink is in seconds
uint32_t new_time = app_data->buffer[0] << 16;
new_time |= app_data->buffer[1] << 8;
new_time |= app_data->buffer[2];
SLEEP_TIME = new_time * 1000;
Serial.print("New Time Set ");Serial.println(new_time);
Serial.print("Sleep Time ");Serial.println(SLEEP_TIME);
taskWakeupTimer.stop();
taskWakeupTimer.setPeriod(SLEEP_TIME);
#ifndef MAX_SAVE
Serial.println("Waking up loop task");
#endif
* @brief Callback for class switch confirmation
* @param Class The new class
#ifndef MAX_SAVE
#endif
m_lora_app_data.buffsize = 0;
m_lora_app_data.port = LORAWAN_APP_PORT;
lmh_send(&m_lora_app_data, LMH_UNCONFIRMED_MSG);
* @brief Send a LoRaWan package
* @return result of send request
//Not joined, try again later
#ifndef MAX_SAVE
Serial.println("Did not join network, skip sending frame");
#endif
return false;
//Battery Voltage**********************************************************************************
// Get a raw ADC reading
analogReference(AR_INTERNAL_3_0);
delay(50);
int vbat_mv = readVBAT();
int vbat_VOLT = (vbat_mv / 10) - 300;
analogReference(AR_INTERNAL); //This takes it back to default (3.6V), so wind direction has full resistance
// Convert from raw mv to percentage (based on LIPO chemistry)
uint8_t vbat_per = mvToPercent(vbat_mv);
uint32_t buffSize = 0;
m_lora_app_data_buffer[buffSize++] = highByte(rain);
m_lora_app_data_buffer[buffSize++] = lowByte(rain);
m_lora_app_data_buffer[buffSize++] = vbat_mv / 20;
m_lora_app_data.buffsize = buffSize;
lmh_error_status error = lmh_send(&m_lora_app_data, LMH_UNCONFIRMED_MSG);
return (error == 0);
void setup(void)
//Rainfall************************************************************************
pinMode(rainPin, INPUT_PULLUP);
attachInterrupt(rainPin, raincounter, FALLING);
time_t timeout = millis();
while (!Serial)
delay(100);
else
break;
// Set the analog reference to 3.0V (default = 3.6V)
// analogReference(AR_INTERNAL_3_0);
// Let the ADC settle
delay(1);
// Get a single ADC sample and throw it away
float readVBAT();
// Create the LoRaWan event semaphore
taskEvent = xSemaphoreCreateBinary();
// Initialize semaphore
// Initialize the built in LED
pinMode(LED_BUILTIN, OUTPUT);
// Initialize the connection status LED
pinMode(LED_CONN, OUTPUT);
#ifndef MAX_SAVE
while (!Serial)
delay(100);
digitalWrite(LED_BUILTIN, !digitalRead(LED_BUILTIN));
else
break;
#endif
#ifndef MAX_SAVE
#endif
// Initialize LoRaWan and start join request
int8_t loraInitResult = initLoRaWan();
#ifndef MAX_SAVE
if (loraInitResult != 0)
switch (loraInitResult)
case -1:
Serial.println("SX126x init failed");
break;
case -2:
Serial.println("LoRaWan init failed");
break;
case -3:
Serial.println("Subband init error");
break;
case -4:
Serial.println("LoRa Task init error");
break;
default:
Serial.println("LoRa init unknown error");
break;
// Without working LoRa we just stop here
while (1)
Serial.println("Nothing I can do, just loving you");
delay(5000);
Serial.println("LoRaWan init success");
#endif
// Take the semaphore so the loop will go to sleep until an event happens
xSemaphoreTake(taskEvent, 10);
* @brief Arduino loop task. Called in a loop from the FreeRTOS task handler
void loop(void)
// Switch off blue LED to show we go to sleep
// digitalWrite(LED_BUILTIN, LOW);
// Sleep until we are woken up by an event
if (xSemaphoreTake(taskEvent, portMAX_DELAY) == pdTRUE)
// Switch on blue LED to show we are awake
delay(500); // Only so we can see the blue LED
// Check the wake up reason
switch (eventType)
case 0: // Wakeup reason is package downlink arrived
#ifndef MAX_SAVE
Serial.println("Received package over LoRaWan");
#endif
if (rcvdLoRaData[0] > 0x1F)
#ifndef MAX_SAVE
Serial.printf("%s\n", (char *)rcvdLoRaData);
#endif
else
#ifndef MAX_SAVE
for (int idx = 0; idx < rcvdDataLen; idx++)
Serial.printf("%X ", rcvdLoRaData[idx]);
Serial.println("");
#endif
break;
case 1: // Wakeup reason is timer
#ifndef MAX_SAVE
Serial.println("Timer wakeup");
#endif
/// \todo read sensor or whatever you need to do frequently
// Send the data package
if (sendLoRaFrame())
#ifndef MAX_SAVE
Serial.println("LoRaWan package sent successfully");
#endif
else
#ifndef MAX_SAVE
Serial.println("LoRaWan package send failed");
/// \todo maybe you need to retry here?
#endif
break;
default:
#ifndef MAX_SAVE
Serial.println("This should never happen ;-)");
#endif
break;
// Go back to sleep
Serial.println("Going back to sleep ;-)");
//Rain*************************************************************************************
void raincounter() {
//Debounce switch
static unsigned long last_interrupt_time = 0;
unsigned long interrupt_time = millis();
// If interrupts come faster than 200ms, assume it's a bounce and ignore
if (interrupt_time - last_interrupt_time > 200)
rain = rain + 1;
last_interrupt_time = interrupt_time;
float readVBAT(void)
float raw;
// Get the raw 12-bit, 0..3000mV ADC value
analogReadResolution(12);
raw = analogRead(vbat_pin);
delay(50);
analogReadResolution(10);
return raw * REAL_VBAT_MV_PER_LSB;
uint8_t mvToPercent(float mvolts)
if (mvolts < 3300)
return 0;
if (mvolts < 3600)
mvolts -= 3300;
return mvolts / 30;
mvolts -= 3600;
return 10 + (mvolts * 0.15F); // thats mvolts /6.66666666
@brief get LoRaWan Battery value
@param mvolts
Raw Battery Voltage
uint8_t mvToLoRaWanBattVal(float mvolts)
if (mvolts < 3300)
return 0;
if (mvolts < 3600)
mvolts -= 3300;
return mvolts / 30 * 2.55;
mvolts -= 3600;
return (10 + (mvolts * 0.15F)) * 2.55;
