Problem with GPS module RAK12501
I am evaluating the RAK12501 GNSS module with a RAK11310 WisBlock Core and have encountered an issue receiving data.
Setup
Base Board: WisBlock
Core: RAK11310
GNSS Module: RAK12501 (L76K)
Slot used: Slot A (the datasheet states Slot A or D are acceptable, while the GitHub example specifies Slot A)
Firmware: Unmodified “WisBlock Sensor RAK12501 GPS Board Programming Guide” example from your GitHub repository
IDE : Arduino BSP in windows
Issue
The board powers on correctly, but even after leaving the device outdoors for more than two minutes, no NMEA data appears on Serial1. I have confirmed that the sketch uploads successfully and that the USB serial port is functioning.
What can I do to solve this problem?
I am getting print in my serial monitor.
GPS uart init ok!
status: Connected
latitude: 	longitude:
status: Connected
Welcome to the forum @Hoon
What example are you using. The example from our Quick Start Guide Basic Sample Code for RAK12501 is giving a different log output, not what you are showing.
Log output of the original example:
(N):LAT=14.421363 (E):LON=121.006958 SAT=12 PREC=1.10
(N):LAT=14.421366 (E):LON=121.006989 SAT=12 PREC=1.10
(N):LAT=14.421384 (E):LON=121.007011 SAT=9 PREC=1.90
(N):LAT=14.421396 (E):LON=121.007034 SAT=8 PREC=1.90
(N):LAT=14.421404 (E):LON=121.007050 SAT=8 PREC=1.90
(N):LAT=14.421407 (E):LON=121.007057 SAT=7 PREC=2.20
(N):LAT=14.421411 (E):LON=121.007080 SAT=5 PREC=3.70
(N):LAT=14.421418 (E):LON=121.007095 SAT=5 PREC=3.70
Where are you testing. Location fix is working outside of buildings. If the view from the antenna to the satellites is obscured by buildings, roofs, … it will in most times not be able to get a location fix.
Beside of above, I found a problem with the used library and it seems TinyGPS is not working well with the L76K RAK12501 module.
I changed the code to use the TinyGPSPlus library and it works well.==> RAK12501_GPS_L76K
Thank you It worked!
