Im using rak4630 in baseboard rak19001 with two ultrawide band modules in IOs, i have been working with the selection resistors for spi in order to have different CS, RST and IRQ and from that point i have not got any problem for weeks. But recently i wanted to add an external SD card reader like the typical from arduino. I connected all miso, mosi and clk throough the pin headers J15, and im using pin WBIO7 as chip select. This connection only with mcu and sd works well. But when i connect everything (2 UWBs and SD card reader), the uwb stop working, im looking if any pin has conflict but i couldn’t see any problem. Im using libraries DS3231-RTC and UWB from rak4630. I also have seen that when i use sd card begin function the rest crashes…
Any idea? thanks in advance
