I am working with the RAK4631 and RAK5860 on the 5005 baseboard, programming the setup via the Arduino IDE. A key objective for my project is to minimize the power consumption of the entire system. I have successfully reduced the power usage of the RAK5860 by driving the ‘WB_IO1’ pin low to power it down. However, I am now looking to put the RAK4631 into a sleep mode.
I’ve noticed there are several commands related to entering low power mode, such as ‘AT+SLEEP’, which I intend to use for managing the sleep state via a timer. But it appears that this requires switching processor cores for execution. While programming for the RAK5860, I’ve been using the nRF board selection. Yet, I believe to utilize the ‘AT+SLEEP’ command, I need to select the RUI nRF 4631 board. Please correct me if this understanding is wrong.
However, I face an issue when I switch to the RUI nRF 4631 board and attempt to compile the LED breathing example; the compilation consistently fails. Here is the error message I encounter. I can confirm that the port is correctly selected. I believe I entered bootloader mode by double tapping the reset, so I’m not too sure what’s going on.
2024-03-24 13:47:05,443 Using board at serial port: COM4
2024-03-24 13:47:05,447 Sending Application image.
2024-03-24 13:47:09,051 No trigger interface found for device with serial number: 9F5DB9B136131E35, Product ID: 0x002A and Vendor ID: 0x239A
2024-03-24 13:47:09,051 Serial: Waiting 500 ms for device to enter bootloader 1/10 time
2024-03-24 13:47:09,564 Serial: Waiting 500 ms for device to enter bootloader 2/10 time
2024-03-24 13:47:10,079 Serial: Waiting 500 ms for device to enter bootloader 3/10 time
2024-03-24 13:47:10,591 Serial: Waiting 500 ms for device to enter bootloader 4/10 time
2024-03-24 13:47:11,104 Serial: Waiting 500 ms for device to enter bootloader 5/10 time
2024-03-24 13:47:11,615 Serial: Waiting 500 ms for device to enter bootloader 6/10 time
2024-03-24 13:47:12,127 Serial: Waiting 500 ms for device to enter bootloader 7/10 time
2024-03-24 13:47:12,634 Serial: Waiting 500 ms for device to enter bootloader 8/10 time
2024-03-24 13:47:13,149 Serial: Waiting 500 ms for device to enter bootloader 9/10 time
2024-03-24 13:47:13,657 Serial: Waiting 500 ms for device to enter bootloader 10/10 time
2024-03-24 13:47:14,170 Serial: Device is either not in bootloader mode, or using an unsupported bootloader.
2024-03-24 13:47:15,179 Serial: No ping response
2024-03-24 13:47:16,187 Serial: No ping response
CompletedProcess(args=['C:\\Users\\katak\\AppData\\Local\\Arduino15\\packages\\rak_rui\\tools\\pc-nrfutil\\v6.1.3/nrfutil', '-v', '-v', '-v', 'dfu', 'serial', '--package', 'C:\\Users\\katak\\AppData\\Local\\Temp\\arduino\\sketches\\E3387AB73D6BA8E52AEF85DF8A376257/Arduino_Led_Breathing.ino.zip', '-p', 'COM4', '-b', '115200'], returncode=1)
File "nordicsemi\__main__.py", line 1545, in <module>
File "click\core.py", line 1137, in __call__
File "click\core.py", line 1062, in main
File "click\core.py", line 1668, in invoke
File "click\core.py", line 1404, in invoke
File "click\core.py", line 763, in invoke
File "nordicsemi\__main__.py", line 1063, in serial
File "nordicsemi\__main__.py", line 980, in do_serial
File "nordicsemi\dfu\dfu.py", line 127, in dfu_send_images
File "nordicsemi\dfu\dfu.py", line 88, in _dfu_send_image
File "nordicsemi\dfu\dfu_transport_serial.py", line 214, in open
pc_ble_driver_py.exceptions.NordicSemiException: No ping response after opening COM port
[34764] Failed to execute script '__main__' due to unhandled exception!
