Hi can anybody help as I am going in circles with the TTN.
I orginally setup my 7268 gateway on the TTN but then deleted it as it wasnt needed. I now need to reconnect the 7268 on the TTN but when I try to add it it states it already exists.
The support forum suggests to either change the dev eui which I believe I cannot do on the 7268 or contact the supplier to change to dev eui.
If the previously used Gateway-EUI is now deleted on the TTI, you should be able to register it again. However, as far as I know, you cannot use the same name. You can use the same Gateway-EUI but the name should be different now since it was already logged as used on the TTI backend. Maybe this is something you can try.
