I’m the recipient of a new RAK7243C Pilot Gateway and I’m having difficulty connecting with it.
Firstly, I don’t have an SD reader/writer so I flashed the image at https://downloads.rakwireless.com/en/LoRa/Pilot-Gateway-Pro-RAK7243/Firmware/ to a USB drive. I connected the gateway to HDMI and so I can see that it boots up given lots of console messages. Hard to say if all is well there though as I don’t know what to look for.
I’m not able to see the gateway advertise its SSID via WiFi. Nor am I able to plug an ethernet cable into it and connect to 192.168.10.10 etc. Further, there’s no ethernet light lit up on the gateway.
I really need to get up and running with the gateway given some tight deadlines. Any help is appreciated.
Some more information. I just flashed another USB drive with 2019-07-10-raspbian-buster-lite and it worked just fine with the RAK7243 - both WiFi and ethernet. Could there be some problem with your firmware, or is it that I’m trying to use the USB drive to boot from with your firmware (again, I don’t have an SD reader/writer).
When you connect the gateway to power up, you need to wait for a while, and its wifi ssid will appear in your wifi list. Do you see his indicator light is on when you connect the power?
So if you want to use USB flash drive instead of SD card i will suggested you to clean install Raspbian Buster and use this Git RAK Common for Gateways for setting up the gateway.
