One (V2)runs since 2 Weeks well,but today the Witnesses drop from 102 to 78
and receive no more beacons
The second one (Gold Esition)is new and a few kilometers away.Its syncing since 3 Days.Helium App shows online/syncing.We have to power our House down for repair.After starting is the miner in Helium App offline,in Hotspotty online.What is now right?And whats the Problem with the dropping Witnesses?
Seeing how you have a gold miner you should have gotten an invite to the Discord, I would suggest you use it to resolve such issues in the future.
As for the current one. Hotspotty is delayed, trust only diagnostics you run directly via pairing.
The witnesses dropping is probably a network issues, if there were a fault with the miner hardware there would ne no witnesses at all.
Interesting I have a rak 2 and simply moved the box over so I powered it down for a bit. Upon turning it back on all the diagnostics checked out just fine. It shows online in the pairing the correct Ip I check port communication all good. No earnings for 10 hrs? Did something change?
A decrease in the number of Witnesses could be due to various reasons, including network connectivity issues, environmental factors (such as changes in the hotspot’s location or surroundings), or problems with the hotspot’s hardware or antenna. You may want to check the hotspot’s physical setup, ensure the antenna is properly connected, and verify that the hotspot has a stable internet connection.
